Old 11-12-2007, 02:54 PM   #1
Default cement porch retaining water
I have a porch with a cement top over brick edges. I believe the brick which is in a square is hollow with the cement top.
The problem I have is the cement top retains water. I know it needs leveling but the water doen't dry up very fast when it rains. My drive way which is also cement dries up very fast.
Is the problem because the cement on the porch does not touch the ground but is hanging over air surrounded by brick walls?
If this is the problem what can I do to correct it?
jerry1967 is offline   Reply With Quote
Old 11-12-2007, 05:49 PM   #2
Driveway is flat and pitched properly so water doesn't stand. Porch isn't. You can use a leveling masonary product, just be aware it will not match the rest of the porch in color.
Ron.
More On This Topic
Whether your family will be comfortable on your porch depends on whether you've built it at a proper level. A level porch helps furniture stay in place and keeps glasses from sliding off your table onto the ground. You need to know how to find and... Read More »
Hi, my name is Peggy Robertson for Expert Village.com. and in this clip I am going to be telling you about hanging plants. Hanging plants are for specific purpose of hanging up. You don’t want to have them on the ground. They are hanging up and... Read More »
Hi, my name is Peggy Robertson and today on behalf of Expert Village.com I am going to do a clip on how to retain water in your potted plants. I know many of us has got up in the morning to go to work in the summer and look outside and see our pots of... Read More »
In our home renovation, we built a new entryway. What we did was this area that you see here connects with a long rock porch that goes around our house. This area, the full length of our house, was a cement porch. It was just bare cement and it went down... Read More »
Hello, my name is Jose Zuniga and I'm representing expertvillage.com. Well we've planted out Mexican Heather, which is great, but remember we've got to maintain the moisture, what do we do? Add some mulch! I happen to have the nugget size mulch here, it... Read More »
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 02:53 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 05:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
help Chuckman Off Topic 8 06-16-2006 12:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 03:07 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
