Cement For Pool Drain Leak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 08:53 AM   #1
cement for pool drain leak
I have an inground concrete pool that had a leaking hydrostatic valve inside the main drain hole at the bottom. I drained the pool and chisseled out the old brass valve. The replacement valves are now 1.5" PVC type.
My question is what type of cement do I use to hold it in place. Regular concrete,Waterproofing cement, cement with epoxy added? I know most anytthing will work initially, but if it sits in water for years, I dont want it to leak after a while.
jerryls is offline   Reply With Quote
Old 06-04-2011, 11:33 AM   #2
Rewards Points: 6,652
Check with the local pool companies to see what they use.
The Following User Says Thank You to gregzoll For This Useful Post:
jerryls (06-04-2011)
Old 06-04-2011, 12:29 PM   #3
Thanks- But that is why I asked here! The local pool companies don't like to give out information and some will even give wrong advice sometimes, as they want to do the job.
Old 06-04-2011, 12:52 PM   #4
Have you tried to ask the private contractors that do the job. Pool companies around our town will let you know the proper stuff to use for maintenance, and not keep it a hidden secret. Stating that they will not help either means you are asking the wrong company, or the approach is wrong. There is a pool forum http://www.troublefreepool.com/index.html that will help better, since the people that use that forum do a lot of their own maintenance.
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 07:23 AM
Drain leak ACampbell Plumbing 3 09-19-2010 08:30 PM
HELP! Cement in PVC drain pipe KAT Plumbing 7 05-18-2006 07:17 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 07:07 PM
Leak at flange and drain pipe tallycat77 Plumbing 1 07-26-2005 08:32 PM
