Cement Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 10:25 AM   #1
Cement Patio
Questions: do i need wood separating the existing foundation and the new porch? I have an existing small cement porch. Do i need to put boards separating as well? I have a very hard soul here in central tx. Do i need to layer with pea gravel?
Socronaut is offline   Reply With Quote
Old 09-22-2011, 10:33 AM   #2
Rewards Points: 150
You can use a wood expansion joint but they make an asphalt based expansion joint that will last longer. It's there to allow the different pours to move independently and not cause damage. In central Texas, depending on the exact location, you may be sitting on the Houston Black Clay which moves a lot between the wet and dry seasons. It's advisable to use a #2 base under the slab of a PI of 17 or less. If you have pea gravel at hand, it can also be used but the #2 base is the standard.
TrapperL is offline   Reply With Quote
Old 09-22-2011, 10:50 AM   #3
What is #2 base and what is pi of 17?
Deck above a cement patio, footing question for the post Adamisu Building & Construction 1 05-25-2011 06:11 AM
brick over existing cement patio cjaybiker Landscaping & Lawn Care 0 10-27-2010 09:47 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 10:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
