Cement Joints - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 08:41 PM   #1
cement joints
have pool deck, boards were used at the concrete joints when the deck was poured. boards are rotten what do i need to use to fill in the joints
Tommy T is offline   Reply With Quote
Old 07-07-2010, 09:35 PM   #2
Rewards Points: 5,336
New boards.
Ron
Old 07-07-2010, 10:10 PM   #3
jlhaslip's Avatar
Rewards Points: 390
remove the old boards, fill the gap with ethafoam (foam rope) and a butyl caulking over that.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 07-08-2010, 06:05 AM   #4
Rewards Points: 4,442
remove 'em, of course,,, then clean the conc sidewalls well & install closed-cell backer rod about 1/2" below the conc's surface,,, best to use a size that needs to be forced into the jnt meaning you won't find it in any apron store,,, industrial or const supply house will have it,,, then seal the jnt w/sika np1 PER DIRECTIONS ! ! ! there are other mtls but you can, at least, find this at your apron store's masonary aisle,,, polysulfide, polyurethane, or 100% silicone's the mtl you want to use im-n-s-h-fo,,, would never use butyl acrylic
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 08:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
