Cement Fiber Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 05:12 PM   #1
cement fiber siding
I just had cement siding put on my home. The contractor drill a hole in the siding to use as the gate latching. My concern and question are, with continued use of opening and closing the gate, won't the cement fiber siding began to start cracking? If so, what fix can I have the contractor use?
lancen is offline   Reply With Quote
Old 07-02-2010, 05:18 PM   #2
kwikfishron's Avatar
Rewards Points: 92
Can you post a picture?
kwikfishron is online now   Reply With Quote
Old 07-02-2010, 05:37 PM   #3
Thanks Kwikfishron for replying. However, I don't know how to post a picture. Perhaps I was not very descriptive in my question. In order for me to now lock and unlock the gate I must remove the gate latch bolt from the the drillled hole the contractor made in the cement siding. I am concern that the cement fider siding will began to crack. It there an alternative that can be used instead of using the drilled hole in the cement fiber board
Old 07-02-2010, 06:03 PM   #4
Rewards Points: 92
I get you now. I’m not as worried cracking as much as I am the hole in the wall and water getting in and the more use the gate the hole will keep getting bigger.
How was it set up before?
Is this a new gate?
This is how you post a picture.
How to attach a photo to a post
Old 07-02-2010, 06:23 PM   #5
Thanks for the instructions on how to post a picture, this will really come handie. Before I had T1-11 siding and used a 2X4 board to hold the gate latch.
Old 07-02-2010, 07:06 PM   #6
Rewards Points: 92
If it’s all working ok I suppose you could glue a receiver in the hole to protect it, similar to a thimble.
Old 07-02-2010, 07:30 PM   #7
Thanks for your idea. I'll find a metal pipe with a little larger diameter and cut it to size.
Old 07-02-2010, 07:48 PM   #8
Rewards Points: 92
PVC would be better than metal.
Siding Options Vinyl vs. Fiber Cement obrien11j Building & Construction 35 09-26-2011 06:08 PM
Painting fiber cement siding david.plymouth Painting 5 09-06-2009 06:25 PM
Primed fiber cement siding and water/rain Scott99999 Building & Construction 2 06-13-2009 09:53 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
