Which Cement Color Is The Best To Mach The Exterior Red Break Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 11:24 AM   #1
Which cement color is the best to mach the exterior red break wall?
Hello! I want to fill the crack with mortar. Since the bricks are red, I have to mix the mortar with the cement color. I saw two similar cement color, red and terra cotta in the HD. Do you have experience to use the cement color? Do you think which cement color is the best to match the red color brick wall, the red or terra cotta? See the red wall at
http://i599.photobucket.com/albums/t...ortarCrack.jpg
. Thank you for your answer.
compiler is offline   Reply With Quote
Old 07-08-2011, 03:00 PM   #2
Rewards Points: 1,016
The terre cotta is probably more orange-ish than you want - so probably the red.
____________
Vince
Old 07-08-2011, 03:58 PM   #3
DIY staff
Rewards Points: 7,174
Take a look at the ceramic tile caulks----they are available in a lot of colors and might be the answer.
Old 07-08-2011, 04:05 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not going to match it. You may only get close.
Using caulk will prove to be a different texture even if sanded caulk is used.
XXX
Old 07-08-2011, 05:42 PM   #5
Too Short? Cut it Again!
You will not match it for sure if relying on the HD offerings. Go see what your local building supply and concrete supplier can offer. My concrete counter/fireplace facade guy can match your wife's nail polish if you are really picky.
Old 07-08-2011, 05:48 PM   #6
I saw some posts suggested using ceramic tile caulks. But, the mortar is the best to use the exterior wall between the bricks. Is it correct? The only problem is no colorful mortar but cement color only after it dries. So, I have to mix the mortar with cement color to repair the mortar between exterior wall bricks. Do you know any better colorful material to repair the mortar? See the picture at http://i599.photobucket.com/albums/t...t/Mortar-1.jpg
Old 07-08-2011, 06:04 PM   #7
Rewards Points: 5,336
Nothing you do will match exactly, but if you are very, very lucky, you will find the perfect match. But then as it ages, it will unmatch because it's not the same as the original product and will age progress differently.
But the crack is so insignificant that you really don't need to worry at all.
Ron
B. Franklin 1759
Old 07-08-2011, 11:11 PM   #8
I am asking about the cement color and material to repair the mortar on the exterior red brick wall.
Old 07-09-2011, 06:58 AM   #9
Yes, I got that.
Ron
B. Franklin 1759
Old 07-09-2011, 08:49 AM   #10
Yes, I got that.
But, I did not see you answered the mortar repair and red cement color are what I needed. Rather, you said something irrelative, didn't you?
Old 07-09-2011, 10:52 AM   #11
concretemasonry's Avatar
Rewards Points: 2,650
compiler -
You started out saying you wanted a mortar to match the red brick when the existing mortar does not match either the brick or the white vinyl. Trying to "tint" a small amount of mortar with a good material (pigment) is like playing with dynamite because it is so strong you would end up counting grains or a powder. Any tinted mortar will always change color as the cement cures.
You have a brick veneer and a vinyl window and you need a good flexible caulk that will stick better the two dramatically different materials/colors. Mortar will not adhere to vinyl and there will eventually be a crack, just as you have now. I suggest getting a quality caulk in a color similar or compatible to the existing mortar, since you will not be able to tint caulk. This is not an obvious problem since you have to be close to even see a crack or color difference AND looking for it.
To do it right, you will have to rout out the mortar between the brick and the vinyl, clean out the dust and caulk properly.
I assume the brick is a real veneer with air gap behind.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Bud Cline (07-09-2011)
Old 07-09-2011, 04:39 PM   #12
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 07-10-2011, 05:39 AM   #13
Rewards Points: 4,796
go find something else to worry about & forget that insignificant crack
it should have been a sealant rather than mortar but those guys got paid & they're gone,,, our home is the same way but nothing will force me to do anything about the crks unless my bride, nagzilla, happens to inspect 'em
The Following 2 Users Say Thank You to stadry For This Useful Post:
Bud Cline (07-10-2011), Ron6519 (07-10-2011)
Old 07-10-2011, 11:33 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This topic has run its course!
Next question.
XXX
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 05:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
