Cement Board For Tub/shower Kit? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2007, 05:43 PM   #1
weekend warrior
Rewards Points: 150
cement board for tub/shower kit?
Right now my bathroom is completely gutted, now that I'm putting it back to together I'm wondering about some durock backing.
I'm only putting tile on the floor
I will have a tub with a 3-piece shower kit, and a ceiling ventilation fan.
I'll apply it to the flooring, but what about the walls, should I do it at all and to what height? Ceiling?
johnny331 is offline   Reply With Quote
Old 10-02-2007, 07:51 AM   #2
Rewards Points: 5,336
For the slight added cost, why not? Just in case water gets behind the seams. I would have it go up to just below the top of the shower kit walls. If you stop it 1" below you can install greenboard or that new sheet good for high moisture areas above it.
Ron
Moisture Barrier behind cement board code? scoot_gt Building & Construction 8 09-29-2007 09:53 PM
1/4" or 1/2" cement board? kemerick Flooring 4 09-14-2007 12:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Bathroom cement board dah General DIY Discussions 2 07-11-2006 07:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
