Cement Or???? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 09:00 AM   #16
Deck Staining Pro
bigchaz's Avatar
I think that sounds like a good plan so far, I dont know much about what type of surface covering is best though. Maybe gravel so it can drain through?
Trimming the fence up some and putting some gravel under there in the trench may help move water along to fence line. Does your drain tie into something else?
Charlie Soden
Apex DeckSavers
NC Deck Powerwashing, Deck Cleaning and Staining
"Bringing New life to Old Wood"
bigchaz is offline   Reply With Quote
Old 01-04-2013, 09:07 AM   #17
No I elbowed the drain to drain off into the dirt area in between my driveway and my neighbors driveway. There are hedges that live there so figured was a safe area to drain to. Though we don't get a TON of water throughout the year. But enough that it leaves this area under te garbages muddy.
Greenie is offline   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
flat cement roof naturallight Roofing/Siding 7 05-11-2012 09:25 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 01:31 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
