Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 02:24 AM   #1
cement
Well lads this is a bit embarassing i am 26 and never mixed cement in my life. I recently started work placement and one of the jobs is fixing a wall. Could some one please tell me how to mix cement properly so i dont look like a complete idiot when i start this project. Thanks.
Philip D is offline   Reply With Quote
Old 01-21-2012, 02:25 AM   #2
cement
Well lads this is a bit embarassing i am 26 and never mixed cement in my life. I recently started work placement and one of the jobs is fixing a wall. Could some one please tell me how to mix cement properly so i dont look like a complete idiot when i start this project. Thanks. Philip
Old 01-21-2012, 02:42 AM   #3
Rewards Points: 2,212
Are you mixing it or is it coming on a truck?
mae-ling is offline   Reply With Quote
Old 01-21-2012, 03:05 AM   #4
just a tool guy
mickey cassiba's Avatar
I'm no expert, but I believe you must mix the cement with an aggregate(SP?) and water. A small amount can be mixed in a wheel barrow with an aggie hoe, larger amounts might require machinery. Could it be you're talking about concrete? That only requires water, but still needs to be agitated in some form or fashion. Many folks here are smarter than I and can give more detailed instruction.
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 01-21-2012, 03:14 AM   #5
Thanks mickey its just putting up a few blocks where a car hit the wall so i think it might be just mortar to be used
Old 01-21-2012, 04:01 AM   #6
You will be using a mortar mix...check THIS out
_______
Check out my Man Blog
jasonreck71 is offline   Reply With Quote
Old 01-21-2012, 04:28 AM   #7
Couldnt get easier than that cheers jason
Old 01-21-2012, 04:40 AM   #8
Retired carpenter
There are many kinds of cement, you probably mean mortar. What do you mean by fixing a wall? Is the wall brick or concrete?
I've had many apprentices in my life. If they didn't know how to do something, by far the best thing they could do is say "I've never done this before; can you show me how to do it?"
When they looked like complete idiots is when they didn't ask, pretended like they knew, and after 30 seconds it was clear that they had never done it before, which is what will happen if you try to mix mortar (and use it afterwards) without having seen someone do it before.
Apprentices are not expected to know everything.
abracaboom is offline   Reply With Quote
The Following User Says Thank You to abracaboom For This Useful Post:
mae-ling (01-21-2012)
Old 01-22-2012, 01:40 AM   #9
Its a gonna be done with blocks outside an old factory.
Old 01-22-2012, 01:06 PM   #10
Rewards Points: 183
Mixing mortar can be as easy as opening a bag and add water until you get it the consistency that you need. If they are making it from scratch then you will be adding cement, lime, sand and water in the proper proportions. I think it is 3 parts sand, 2 parts lime, one part portland cement and enough water to make it workable. I might have the lime and cement portions backwards so check on that.
paul100 is offline   Reply With Quote
Old 01-22-2012, 11:39 PM   #11
Thanks everyone for your help.
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 08:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
