Old 09-22-2011, 06:05 PM   #1
Celotex/Masonite behind Cedar Shakes
While having a contractor remove the shakes from a deteriorated side of my new home, I noticed that behind each course of red cedar shakes, there is a masonite/fiberboard type material, lapped in similar fashion as the shakes.
After noticing this, I started looking at the underside of all the intact sections of siding on the house, and noticed that the fiberboard is visible, about at a depth about 1/2 inch less than the exposure of the shake on top of it.
Three questions:
1. Does this material pose a moisture threat?
2. I noticed that the exposed edge of the fiberboard behind the shakes is not painted. Are painters deliberately not painting this area, so the house can breathe? Or when I re-paint the house, should I "smoosh" paint up and under there to help lock out moisture infiltration?
3. When I have the shakes replaced, will they appear flatter (lack depth) not having the fiberboard behind each course? Should I have some alternate material installed behind each course as well?
shub is offline   Reply With Quote
Old 09-22-2011, 08:01 PM   #2
Tom Struble's Avatar
i'ts normal,don't try to seal it and use an under-course if that's the look you want
Tom Struble is offline   Reply With Quote
Using Felt with Cedar Shakes freddmc Roofing 32 10-08-2011 12:26 PM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 08:51 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 10:10 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing 5 10-12-2006 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
