Cellulose Over Blown In Fiberglass? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 10:52 PM   #1
cellulose over blown in fiberglass?
I did some work in the attic and disturbed some blown in fiberglass insulation. I decide to add some more. Now I'm considering whether to use cellulose or fiberglass. From what I read online, it looks like cellulose has many superior properties over fiberglass. It's cheaper, it prevents convection, it seems to have less problem with settling.
My question is, is it a good idea to mix blown in fiberglass with cellulose? Will adding cellulose on top of fiberglass provide the benefit of preventing convection, or will it compress the fiberglass to much and result in significantly lower R-value (from the fiberglass alone)?
deerhunter is offline   Reply With Quote
Old 10-29-2010, 11:16 PM   #2
Registered User
Rewards Points: 4,924
With a zip code starting 393, the attic should be R-38: http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html
Cellulose, blown in at 1.5 to 2.2# per sq.ft., weighs average 0.14# times how much you want to achieve the required R-value amount. 7” is about a pound or a full pop can on a foot square of fiberglass batt compressing it about two inches reducing the R-value by 3 if 2x8 or 5 if R-30 now. If ” drywall and 24”on center ceiling joists, don,t exceed the 1.7# insulation recommended or 2.2# for 5/8”
Gary
Insulation - Cellulose vs. Icynene meth Building & Construction 25 12-17-2014 11:04 PM
Cellulose blown in insulation questions... 1eagertolearn Remodeling 3 10-02-2010 12:42 AM
What's the difference between blown fiberglass vs. cellulose? handy man88 General DIY Discussions 14 02-14-2010 10:01 AM
Is fiberglass insulation safe for us with dishwasher? jen78fl General DIY Discussions 10 01-31-2008 06:51 PM
insulate floors or attic first? pesphoto Building & Construction 16 12-12-2007 02:03 PM
