Ceiling Tile Around Sprinkler Heads - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 10:20 AM   #1
Ceiling tile around sprinkler heads
I'm cutting out for sprinkler heads in ceiling tile and I just can't get the right measurement is there an easy way to do this??
Turbo2345 is offline   Reply With Quote
Old 04-18-2011, 12:38 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
If I have an unusual shape or cut I will often make a template out of cardboard, then transfer it onto the tile. There may be better/faster ways, but it works for me.
Old 04-18-2011, 03:00 PM   #3
Old School
Willie T's Avatar
Try laying the tile down flat in front of you EXACTLY in the orientation it will occupy upon installation (finish side down) and then when you transfer your measurements from the inside vertical piece of the grid they will fall right where they should on the back of the tile.
Measure to the pipe and add half of the diameter (trying to eyeball the fattest part of the round outside takes some practice, so just measure TO the pipe and add 1/2 of the outside diameter of the pipe) Do this from two perpendicular sides. Poke an ice pick or an awl through where the two lines cross. (That will be the center of the hole.)
Turn the piece over and carefully cut a circle out with a slim, sharp kitchen knife. The hole should be just the size of the pipe, or maybe an eighth of an inch larger.
Of course, to do this right, the water has to be shut off and the heads all removed first. (NOTIFY YOUR FIRE MARSHAL FIRST !!!) It's REALLY hard to get a perfect cut when trying to encompass the entire installed sprinkler head. REALLY hard! I wouldn't even suggest trying. Getting past that head hanging down is tough. And even trying to is just punishing yourself needlessly.
THEN you will usually have the hassle of getting the piece of tile to fit the pipe AND the grid all at the same time. No where near as hard as getting over the whole sprinkler head, but still a challenge. This part just takes patience. Often you will find loosening a few wires on the grid helps so you can lower the grid a little...... but remember to put those wires right back up in the proper original elevation.
Sometimes you get lucky, and you can lift the pipes a half inch or so. But not often.
Willie T
Old 04-18-2011, 06:08 PM   #4
Thanks so much for your advice, unfortunatley i was working in an operating plant and the sprinkler guys installed the heads already, then my phone died so i couldnt check your post, what i did is measure from two sides of the grid and got the center mark, put the tile finish side up and got my chrome cup on there and made sure it was center. Then once it was center i hit it with a hammer and pushed it through making a perfect circle. Then putting it in i raised one end up and put the head through then the other end while raising it at the same time. while a pain in the butt it worked for the time being. thanks for your reply.
Old 04-18-2011, 06:43 PM   #5
Old School
Willie T's Avatar
Glad you got it working for you.
Willie T
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
ceiling tile labor only ericme972 Off Topic 2 06-16-2010 08:04 PM
getting rid of ceiling tile dust notsodiy Building & Construction 12 09-02-2009 12:18 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
