Ceiling Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 03:06 AM   #1
ceiling studs
I bought the studs 1by4's for furring the joists. I found they are actually half inch thick. will that work for my ceiling, Or should I change them?
raulakh is offline   Reply With Quote
Old 09-26-2009, 11:50 AM   #2
Registered User
Termite's Avatar
If you're running them perpindicular to the joists I'd suggest a minimum 1" nominal (3/4" net) thickness.
Old 09-26-2009, 11:59 PM   #3
Smile
Thank-you:
Metal Studs for Ceiling? fivecitydjs Remodeling 14 08-06-2009 01:32 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
