Ceiling Span Vs. Joist Size - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 08:38 PM   #16
Rewards Points: 1,062
Originally Posted by ratherbefishing View Post
Dude,
I sent you a link for the simple calculation. It says (assuming Douglas Fir) that you can use 2x6s for ceiling joists. Unless you are trying to reuse your old 2x4s (and I can undestand that), 2x6s don't cost that much more. If you are trying to reuse your old 2x4s, just space 'em 12" OC. The insulation can be taller than the joists, so you can still use R-30 (code here) if you want to.
thanks, i was referring to the 2x10 suggestion. no, i'm not reusing old and i was planning on 2x6. i hope SPF lumber from HD/lowes is (as strong as) Douglas Fir.
Old 02-04-2012, 09:08 PM   #17
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Dude,
But...the op said the rafters are the joists. There is no attic.
If all you want is R-13 or 19...
Unless I'm reading something wrong.
Uh...I went back and re-read the posts. I think you're saying it's just as I understand it, ie no attic in your
first post, then you changed it a little while ago with the bold print "the joists aren't holding the roof" in a later post.
You can't have it both ways.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
amakarevic (02-04-2012)
Old 02-04-2012, 09:17 PM   #18
there is an unusable gap between the two. it is too small to be used for anything. but the rafters can't be used for ceiling cause they are slanted. so the joists i'm putting in are just to make the ceiling level.
sorry for the confusion. i should have made that clearer in the OP.
thanks
Old 02-04-2012, 09:20 PM   #19
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Southern-pine-fir has varying grades also, just like Doug Fir.
For a 9' span you can use SPF on 16" centers for a dead load of 5 lbs. and a live load (without storage) of 10 lbs.
All grades of either species works.
Just remember that I am not suggesting you to do anything here, just disseminating a little prescriptive info.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-04-2012, 09:22 PM   #20
Disabled wood vet
titanoman's Avatar
[QUOTE="amakarevic"
sorry for the confusion. i should have made that clearer in the OP.]
So your roof (the outside) has one slope to it, and there was a different slope on the inside ceiling, so you took those out and want to put them back level, right?
Old 02-04-2012, 09:40 PM   #21
Rewards Points: 192
Is it possible that these old 2x4's were possilby true 2x4's slow growth lumber and not the current 1 1/2 x 3 1/2 fast growth lumber.
bcgfdc3 is offline   Reply With Quote
Old 02-04-2012, 10:47 PM   #22
the roof is pitched maybe 15 deg. the ceiling should be pitched 0 deg. at the highest, the gap between the two is maybe like a foot, if that.
Old 02-04-2012, 10:48 PM   #23
i dunno slow vs. fast growth but the size was definitely the new, reduced size
Old 02-05-2012, 01:35 AM   #24
Rewards Points: 34
Ok, I suggest 2x8's or 2x6's. From what I've read, we're talking ceiling joists, not rafters, to basically hold up drywall. No live load? C'mon, I gotta call the government to do that in my own place???
tompatrick is offline   Reply With Quote
The Following User Says Thank You to tompatrick For This Useful Post:
amakarevic (02-05-2012)
Old 02-05-2012, 04:00 AM   #25
you got that right, sonny... you're being watched. heck, we can detain you indefinitely for building without permits... and put a lien on your house.
but hey, it's all for the sake of everyone's safety. don't you feel safe?
Old 02-05-2012, 05:27 AM   #26
Hilti Construction Ltd.
Unless you know your building codes, have the experience, and are qualified to complete the job successfully, all structural building projects need a permit! - Ty owner (Hilti Construction Ltd.)
Hilti is offline   Reply With Quote
Old 02-05-2012, 09:07 AM   #27
Rewards Points: 506
Originally Posted by Joe Carola
Amazing all the questions you have about doing structural work illegally on your house......and yet people here answer and don't care either.
Joe, Hilti, et al.,
I'm using a mobile device, so I can't see the OPs full profile, to know his location. But YOU have got to realize that there is an abundance of people who live in rural areas where building code enforcements and permits are literally non-existent. Not everyone is breaking the freakin' law when they want to put together some structure with their own brain and hands.
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
Old 02-05-2012, 10:07 AM   #28
Disabled wood vet
titanoman's Avatar
Originally Posted by jlmran
Joe, et al.,
Thank you. That's what I keep saying and it pee's some people off.
Some people (and I'm not mentioning any names) think they are the permit police.
It's up to the DYI'er if they want or even can get a permit.
Permits should be for people that desire the input from somebody in an official capacity so they know what they are doing is safe or so they know their contractor is doing their job right.
Like I mentioned earlier, you can build as big of a house as you want at the Lake of the Ozarks and the only permits you need are for septic systems and fire.
I don't think that's enough.
In California, you have to have your pier holes for your deck (and the way the rebar is tied, loop it twice) and your drywall nail pattern inspected.
I think that's too much.
But It's none of my business what people do on their own jobs.
I might suggest they go to their planning or building department, if they have one, for spanning codes or something.
But unless they're doing commercial work, which I doubt DIY'ers are, I don't care and I'll answer their building questions the best I can.
Old 02-05-2012, 03:10 PM   #29
why doesn't this forum have the functionality to block useless commentators? Like FB
Old 02-15-2012, 08:23 AM   #30
PoleCat's Avatar
Rewards Points: 1,638
My opinion is that a DIY forum should never have a reply posted that advises getting a "pro" or a finger wagging "you'll need a permit" snipe. If this is the only comment an individual can conjure up then the best service they can provide is to NOT reply at all.
PoleCat is online now   Reply With Quote
Tags
ceiling
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 05:41 PM
remove ceiling joist brace daylily Remodeling 2 08-02-2009 08:45 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
correct joist size for attic helpless handyman Building & Construction 1 07-06-2006 12:29 AM
