Ceiling Sheetrock Sag Fix - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-01-2007, 03:18 PM   #1
Ceiling sheetrock sag fix
this house was moved onto property maybe 30 years ago,the section of ceiling where two parts of the house were attached has begun to sag. On removing the mud/plaster covering the sheetrock we discovered that a 10"wide area had been sheetrocked with 1" wide pieces not nailed into a 2x4. (The sagging has caused cracking the width of the room) This 10" area spans the width of the room 19ft.. IS there any way to fix this without putting in a beam? Thanks
doitmyway is offline   Reply With Quote
Old 10-01-2007, 07:40 PM   #2
You could cut everything out from Joist to Joist and replace it with rock that is attached to the joists.
jiggyjack is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 10:50 PM
Mating sheetrock to textured ceiling atlfiveo Building & Construction 2 02-05-2007 10:43 PM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 08:38 AM
