Ceiling Joists - Drywall Load Only - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 07:23 AM   #1
Rewards Points: 101
Is there specific guidelines to go by or a table available for ceiling joists sizing for carrying drywall only? I have a span of about 10 ft and would like to use 2 x 4's if possible, however I am just not sure if these will be strong enough to carry the weight of the drywall and do not want any future problems.
Tom
Thomas
South Jersey - Camden County
tjbingha is offline   Reply With Quote
Old 02-14-2013, 09:09 AM   #2
Rewards Points: 13,450
Go with a minimum of 2 X 6's, 8's would be even better.
2 X 4's will just sag and cause cracks.
tjbingha (02-14-2013)
Old 02-14-2013, 09:12 AM   #3
http://www.wclib.org/pdfs/SimpSpanTbls.pdf
But call your local building department for specifics. ie live/dead loads
JonM is offline   Reply With Quote
The Following User Says Thank You to JonM For This Useful Post:
Old 02-14-2013, 09:22 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
This depends on your local building code (if any), and the type of attic space your have. Live loads can range from 10 pounds per square foot for attics with limited height to 30 pounds per square foot for attics that can be accessed by fixed stairs. It is also dependent on the wood species used.
See pages 11 and 12 of the American Wood Council's "Span Tables for Joists and Rafters". These table are found in the International Residential Code.
Kiln dried 2x4 spruce-pine-fir "could be" used at a 10' span with 10 psf live load at a spacing of 16" o.c., however that would be at the outer limits of the allowable span. As Joe stated you'll have more sag than if you framed using 2x6 or 2x8. I would probably recommend a 12" o.c. spacing should you decide on the 2x4's.
Again framing size and spacing is determined by the actual live load of the attic space and species of wood used.
Hope this helps! Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-14-2013, 09:30 AM   #5
Rewards Points: 101
This will not have attic space and will not be carrying any snow/roof load. Only the weight of the drywall/recessed cans (two of them). I feel very stupid but I have a difficult time in reading these span tables provided. I have an engineer coming in again on Saturday to confirm this and another few items, I just wanted to get an idea and order the wood so that I can complete on Sunday.
Thanks for all your help guys...
Tom
Thomas
Double Layer Drywall Ceiling Falling Neighbor Lee Drywall & Plaster 13 12-05-2012 03:11 PM
Drywall over open beam ceiling and venting daluu Remodeling 4 11-07-2012 12:54 AM
Removing Ceiling Drywall maenos Drywall & Plaster 14 03-08-2011 09:48 AM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 06:20 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
