Ceiling Joist Size - 2x4 Or 2x6 Needed? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2007, 02:02 AM   #1
Question
ceiling joist size - 2x4 or 2x6 needed?
Hi, this is my 1st post here! Thanks in advance for any help!
Here is my situation: I'm finishing off a gameroom under my house and there is currently about a 9 foot ceiling from the floor to the bottom of floor joists with several pipes, plumbing, electrical, etc. attached to the bottom of the floor joists. I want to put in a ceiling @ 8 feet to hide all of that stuff - everything is within about 8 inches of the bottom of the floor joists overhead. The room is 14 feet wide by about 25 feet long. My question: Spanning the room in the 14 foot direction, can I use 2x4's or do I have to use 2x6's? Can I use 2x4's if I attach them to the floor joists above with strapping or 2x4's to prevent sagging in the middle and for extra support? The ceiling joists will just be for supporting drywall - no additional loading or storage issues. Any thoughts?
Thanks!
bigdaddy352 is offline   Reply With Quote
Old 08-20-2007, 05:57 AM   #2
Builder/Remodeler
ChrWright's Avatar
14' is too long for a 2x4 to span and not sag when you attach the drywall.
You are correct though, that you can add blocking to support the mid-span of the 2x4 from the existing joists.
Good Luck
ChrWright is offline   Reply With Quote
Old 08-20-2007, 06:05 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
First off, Welcome and we are glad that you found the site.
....My question:....Can I use 2x4's if I attach them to the floor joists above with strapping or 2x4's to prevent sagging in the middle and for extra support? The ceiling joists will just be for supporting drywall - no additional loading or storage issues. Any thoughts?
As previously answered = yes. You already have the right idea.
- Build Well -
Old 08-20-2007, 10:22 AM   #4
Thumbs up
Thanks for you rapid replies!!!
Thanks again - this site is awesome!
Old 08-20-2007, 12:42 PM   #5
Custom Cabinet Maker
That is the reason suspended ceilings were invented and used. Remember once you sheetrock that ceiling and you have a problem later on, you have to rip it out, patch etc.
skymaster is offline   Reply With Quote
Old 08-20-2007, 06:23 PM   #6
You stole my thunder, but Sky is right on the money.
jiggyjack is offline   Reply With Quote
Old 08-20-2007, 06:55 PM   #7
Jiggy; hmmmmmmmm Sky, thunder works for me.
However I will recind my coment to allow you to say it instead ROFLMAO
JackM
Next question comming will be how to install it I will let you handle it LOL
Old 08-20-2007, 07:00 PM   #8
Access panels, access panels....(I hate the look of Dropped ceilings)
- Build Well -
Old 08-20-2007, 09:01 PM   #9
hmmmmmmm, coffered ceiling, loose raised panels, Oak, etc. Yes Craig you got it. Time to fire up my shaper eh? :}
Old 08-21-2007, 12:02 AM   #10
Let me see. A nice Sheetrock ceiling. Smooth nice looking or wait I can get a wall mart ceiling. Come on if you finish a basement correctly you really do not need access panels ( maybe one for something ). But if you want nice looking and not make your basement feel, well like a basement drywall is the only way to go.
warnerww is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Lighting tip needed for vaulted ceiling wease Electrical 5 02-24-2007 11:49 PM
correct joist size for attic helpless handyman Building & Construction 1 07-05-2006 11:29 PM
ceiling joist this old house Building & Construction 2 03-23-2006 09:00 AM
