Ceiling Joist Size For 10.6 Foot Width Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 04:50 PM   #1
ceiling joist size for 10.6 foot width room
Can't seem to find a link online for the specs for a ceiling joist beam to support the trusses on a tar and gravel roof for a room that is 10' 6" wide. I took out a petition wall that was separating two rooms to make one long room. Could someone direct me to a website that provides uniform building code for this particular issue in the state of Florida.
hammeredmythumb is offline   Reply With Quote
Old 08-26-2009, 05:35 PM   #2
I do not know of any beam sizing software on the web
If you need to put a beam in to support floor etc where you will need to have a beam sized
My local Lumber Co did this for free, other areas they may not do this
Did you verify the wall was not load bearing before taking it down ?
If you have trusses or ceiling joists that landed on this wall then it was load bearing & you should have a support wall up until the beam is in place
Pics of the opening/roof would help
Old 08-27-2009, 02:22 PM   #3
Rewards Points: 1,910
Sounds like you need a copy of IRC Table R502.5(2). There is a website somewhere on line that posts State Codes. If the State Code refers to IRC the website posts a copy of the IRC. I can't remember where it is but I found it a couple years ago. Keep searching the web and you'll find it.
Old 08-27-2009, 05:56 PM   #4
Registered User
Rewards Points: 526
It's on page 9 of this free download: http://rapidlibrary.com/download_fil...ing+Codes+.rar
It's only the 2003 version, with some '97 references.
Be safe, G
Old 08-28-2009, 01:54 PM   #5
TooledUp
I would check with your local lumber company or even some residential steel suppliers will tell you what you need if you buy the material from them. Something like that I would definately get an experts opinion.
TooledUp is offline   Reply With Quote
Tags
ceiling joist , code for ceiling joists , header , remove support
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 09:12 AM
Repairing 2x4 foot drywall in ceiling LukeCT Remodeling 2 03-21-2008 11:55 PM
ceiling joist size - 2x4 or 2x6 needed? bigdaddy352 Building & Construction 9 08-21-2007 12:02 AM
How to improve a low ceiling room Anita Turley Painting 20 01-10-2007 12:17 AM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-24-2006 11:23 PM
