-   -   ceiling joist (http://www.diychatroom.com/f19/ceiling-joist-2100/)
this old house 03-23-2006 12:32 AM
ceiling joist
i own a ranch house and i want to take a wall out but the ceiling joist rest on the wall. i dont want a beam showing so is a nother way to hold the ceiling joist up its about a 12' span. i was thinking about useing the roof rafters to hold the ceiling joist in that span. with 2x6
redline 03-23-2006 06:57 AM
How long is the wall that you will be removing?
Does the wall run parallel or at a right angle to the ceiling joists?
How wide are the ceiling joists?(4,6,8,10 inches..)
Darylh 03-23-2006 09:00 AM
Could you post a quick drawing and a little more info on the following
size of ceiling joists
head room above ceiling joists
size of roof rafter
span of roof rafter.
Personaly I would not use the rafters for support. To much weight and if you get a heavy snow load you could be in for some real trouble, but if you have the room above the ceiling joists you might be able to create a beam set up . I have done this once but the wall that was removed was well into the center of the house and there was room to do this.
