Ceiling Joist - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 07:25 PM   #16
KShirriff is offline   Reply With Quote
Old 10-09-2012, 07:45 PM   #17
Civil Engineer
Rewards Points: 4,682
Help me out here. This is a complex design, with complex framing. I am guessing that it was designed by someone, perhaps an architect? Maybe there are plans? Maybe this is a standard design built off plans? It is usually a good idea to follow approved plans, assuming you have them. The size of the house and the complex framing suggests that you didn't just start building this thing based on intuition. So perhaps you can back up and describe what the plans call for in terms of tieing the framing together, and whether you have deviated from the original plans, and if so exactly how.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
AndyGump (10-09-2012)
Old 10-09-2012, 07:46 PM   #18
Old 10-09-2012, 07:46 PM   #19
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
From you pictures and your questions on this I can deduce that you or maybe your contractor or both are designing this on the fly.
The connections and lack of hardware makes this kind of evident.
You did not put in your location, do you require permits in your area? Probably not as you are not going by a plan.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is online now   Reply With Quote
Old 10-09-2012, 07:49 PM   #20
I am installing ceiling joist upstairs and connecting to a cathedral ceiling.The ceiling joist are 2x6 running 13' on 16" centers. I need to connect to the cathedral ceiling joist that are running the opposite direction at 8' span. Do I need to create a header beam to tie these joist together. If so, what size? Rule of thumb is 1" per foot. Would that mean a 2x8 doubled up with 1/2" OSB be sufficient?
Old 10-09-2012, 07:51 PM   #21
This is a panelized house.It was a shell only. I am trying to finish the interior walls and ceiling myself
Old 10-09-2012, 07:54 PM   #22
No permits. way out in the country
Old 10-09-2012, 07:55 PM   #23
AndyGump's Avatar
Rewards Points: 666
Oooohhh, I think I should get a prize.
Andy.
Old 10-09-2012, 09:09 PM   #24
Old 10-12-2012, 11:38 PM   #25
Thanks Hand Drive, I like your opinion. Nobody else seems to step up to th plate...except for some ego boosts
Old 10-13-2012, 07:48 AM   #26
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
Shirriff....one word.... "Simpson".....download their catalog....or pick one up....it will be your friend and saviour....
For the built up post...you should put an end cap on there such as an ECCQ....then at the bottom you want something that will prevent the bottom from being knocked out of the way.....it would really suck to see what would happen if someone shoved a piece of furnature around and hit that post....knocking it out of place....
Yea.....your missing a lot of hardware......click on the link in my signature and look at some of the hardware that is in my 2-story addition....I have vaulted ceilings...but....not nearly as complicated as yours....
Permit or not....you want to do it right....it's a lot cheaper to put in the hardware now than try and fix it later.
BTW....would love to see an outside pic.....please keep us posted...
ddawg16 is online now   Reply With Quote
Old 10-15-2012, 07:46 PM   #27
Old 10-15-2012, 07:48 PM   #28
Thanks Dawg ...Going with the rustic look...eventually doing rock at the base and chimney.Still have to finish landscaping also
Tags
ceiling joist , ceiling joists
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 09:34 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 12:21 AM
Bad news - asbestos and a failing ceiling joist system sheslostcontrol General DIY Discussions 17 05-30-2011 11:34 AM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 05:07 PM
