Old 10-04-2012, 10:39 PM   #1
Ceiling joist
I am installing ceiling joist upstairs and connecting to a cathedral ceiling.The ceiling joist are 2x6 running 13' on 16" centers. I need to connect to the cathedral ceiling joist that are running the opposite direction at 8' span. Do I need to create a header beam to tie these joist together. If so, what size? Rule of thumb is 1" per foot. Would that mean a 2x8 doubled up with 1/2" OSB be sufficient?
KShirriff is offline   Reply With Quote
Old 10-06-2012, 09:26 PM   #2
Moderator
Ceiling joist
Welcome to the forums!
This is where a picture or three would help; How to resize photos to post them here.
Gary
Clothes taking longer to dry?
Old 10-06-2012, 09:30 PM   #3
Civil Engineer
Ceiling joist
Except for certain very common headers (yours does not sound like a common header), headers are generally designed for the specific load imposed on them. The subject of how to determine load on a header has been discussed many times on this forum, you may want to do a search. Sometimes the lumber yard that supplies the glulam or lvl beam (if that is the type of beam you use) will incorporate the cost of engineering the beam into the price of the beam, so you can avoid the need to hire an engineer or architect.
Old 10-07-2012, 09:30 PM   #4
Ceiling joist
Well.. both ridges are supported with LVL beams, I'm just trying to frame a ceiling below the beams, tying the ceiling joist into the 2x8 rafters. But my concern is, can I tie the 2x6 joist together when the front A-Frame ceiling joists are running East to West and the back ceiling joist are running North to South. How do you tie that together?
Old 10-07-2012, 10:27 PM   #5
GBrackins's Avatar
Ceiling joist
KShirriff,
where are you located? I ask because typical energy code requirements can be difficult to meet in parts of the country when using 2x6 rafters.
I agree with GBR, a few photos would certainly aid in your case.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 10-07-2012, 11:13 PM   #6
Ceiling joist
in western ny 12 foot is maximum for a 2/6 for a ceiling joist.
Old 10-08-2012, 10:21 PM   #7
Ceiling joist
Old 10-08-2012, 10:23 PM   #8
Ceiling joist
Old 10-08-2012, 10:25 PM   #9
Ceiling joist
Old 10-08-2012, 10:27 PM   #10
Ceiling joist
I plan on spray foaming the roof and walls. This is in Alabama, so there is not a snow load and I am not using the attic space for storage.
Old 10-08-2012, 11:00 PM   #11
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Ceiling joist
Dang man, if I had your money I would burn mine.
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
Old 10-09-2012, 10:37 AM   #12
AHH, SPANS!!!
Ceiling joist
What I would do is try and get an upsized double ceiling joist tied to the double valley rafter somehow and then use joist hangers to hang the remaining fill in joists in the center off of the double joist. Also, use the center post and tie a couple of the joists on the hangers to it on either side as they cross it. Getting the cut right where the double hits the valley rafter is the hardest part...
hand drive is offline   Reply With Quote
Old 10-09-2012, 10:51 AM   #13
GBrackins's Avatar
Ceiling joist
is that a built-up column under the end of the ridge beam in photo 1? has anyone calculated the column requirements or did they just nail some 2x's together? I ask because the column appears to be quite tall and does not appear to be laterally braced anywhere between the top and bottom of the column. Depending on several factors such as column material, fasteners to join built-up column, column cross section area, column height and load supported it may or may not be stable. Last thing you'd want is for the column to buckle.
Not questioning anyone knowledge or abilities, just asking a question in case it was overlooked.
Gary
Old 10-09-2012, 08:21 PM   #14
Ceiling joist
Yes it is a built up post. It is four 2x4's 11' long supported on the 2nd floor with a LVL beam below that.What should I do there? Can I beef it up?
Old 10-09-2012, 08:24 PM   #15
Ceiling joist
Tags
ceiling joist, ceiling joists
Adding wall with door opening - sloped ceiling and no joist for top plate Jebross Remodeling 11 01-11-2012 10:34 AM
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 01:21 AM
Bad news - asbestos and a failing ceiling joist system sheslostcontrol General Discussion 17 05-30-2011 12:34 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 06:07 PM
