Old 03-11-2010, 09:35 AM   #1
Ceiling Insulation in Basement
I'm in the process of finishing a basement. It currently has bat insulation in the ceiling of the basement and my question is this. When I finish the ceiling (either drop or drywall) should the bat insulation stay or go? Pros and cons? My gut sez leave it for, if nothing else, sound proofing.
Any and all thoughts?
Thanks,
upinsmoke is offline   Reply With Quote
Old 03-11-2010, 09:56 AM   #2
Xtreme DIY'r
I'd leave it, unless you have some specific reason to remove it
Will you have heat in the basement ?
Old 03-11-2010, 10:50 AM   #3
Leave it.
walkman is offline   Reply With Quote
Old 03-11-2010, 02:58 PM   #4
Currently the basement is not heated, but my intention (early in the project) is to have the HVAC lines,vents,return run so that it will be. I know some of the insulation will have to come down in order to facilitate the running of the new lines so once it's down I didn't know whether to go to the trouble to reinstall it. It sounds like maybe I should.
Just wanted to make sure there wasn't a down side to leaving it that I hadn't considered.
Basement Insulation raulakh Building & Construction 2 10-13-2009 01:36 AM
Basement Insulation R Value tjeieio Carpentry 6 09-08-2009 10:24 PM
Insulating unfinshed basement ceiling for sound daveyd Building & Construction 38 02-02-2009 11:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
