Ceiling Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 09:02 PM   #1
ceiling insulation
I recently bought a log cabin in KY. The ceilings are wood on top of the rafters. I think there is just a layer of tar paper on top of the wood, then a layer of plywood then the metal roof. The cabin looks good from the inside and outside, but it has no insulating properties at all in the ceiling. If I install styrafoam in between the rafters and fill that entire 6 inch area up, then install new a new wood ceiling, do I need to leave a space between the insulation and the existing wood ceiling?
dsanford is offline   Reply With Quote
Old 01-17-2009, 10:37 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
yes if your going to insulate the roof rafters and then install drywall ceiling you need 1 1/2'' air space but that is only part of your problem.
You also need proper venting at the eaves and a ridge vent
Tom Struble is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
ceiling insulation question christy123 Roofing/Siding 15 12-18-2008 01:22 AM
R30 ceiling insulation with 2x4 roof trusses I_think_I_conduit Building & Construction 4 04-04-2008 04:43 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 10:55 AM
