Ceiling Ideas - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 05:06 PM   #1
ceiling ideas
Looking to have slope style ceiling in dining room. Looking for input best way to do it .. would like open roof board style but our canadian climate winters wouldnt be very efficent so to insulate aganist roof boards not a good idea, then install a board look on inside, currenly have 2x4 roof trusses stick bulit on angle and wide open to do whatever any sugestions ? txs
hvac dude is offline   Reply With Quote
Old 09-06-2012, 05:25 PM   #2
Rewards Points: 13,960
You need to go back and edit your profile so people will know where you live for better ansewers.
Not a great plan unless your willing to go though a whole lot of steps to do it.
If you Google "insulation Zone map" it will tell what's suggest for insulation in your area.
Your going to have to allow for two differant things, Venting, insulation.
Just having 2 X 4's leaves you with almost no room for either.
It is possible to add onto the 2 X 4's to allow more room for insulation.
Your also going to be loosing a lot of avalible heat sitting up at the ceiling doing nothing.
Old 09-06-2012, 05:41 PM   #3
i can scab some 2x's to exsisting 2x4 no prob at all
Old 09-06-2012, 05:50 PM   #4
Looks like your going to need a minimum of R-40.
You may want to look into having a company come in a spray foam.
Old 09-06-2012, 05:56 PM   #5
What about ventilation in between the space ? i've read and they suggested having the space vented if i foam then no ventilation
Old 09-06-2012, 06:31 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
if you have existing soffit vents and a ridge vent and still want to use spray foam they can install an insulation baffles in the rafter bays. this will provide ventilation from the soffit to the ridge vent. they can then spray foam from the bottom side of the insulation baffle to your ceiling.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
mae-ling (09-06-2012)
Old 09-06-2012, 06:53 PM   #7
this is a renovation im doing i im able to adapt anything that needs doing
Old 09-06-2012, 08:17 PM   #8
Rewards Points: 2,212
Can you post pics?
They help a lot.
If your rafter is just a 2x4 it may not really be strong enough.
Or do you have trusses?
mae-ling is offline   Reply With Quote
creative plywood ceiling ideas? t_mccann Remodeling 12 02-28-2012 02:16 PM
Bar ceiling ideas Mills314 Carpentry 26 01-10-2012 09:51 PM
An extensive 'drop ceiling' project- where to begin... kpatten Remodeling 7 02-05-2010 06:31 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
