Old 07-25-2007, 12:17 PM   #1
Ceiling height, Raising of
Please see attachment for x2 drawings of current situation & what I want to achieve, and x3 photos of existing situation.
I have an enclosed porch that was turned into living space by a previous owner. The roof structure of the porch is original to the house, built 1953. The existing ceiling height is 7'4" and 1/4" plywood.
I want to raise the ceiling height 2', or higher if possible.
my questions:
1) How to firmly tie/affix the angled roof members onto the wall header without the cross joists sitting on the wall header and roof beams holding the wall header and roof beams together. (see drawing attachment)
2) How high can I raise the cross joists up the roofing members before stability is an issue?
3) What is the best way to affix the cross joist members onto the angled roof members -Nails, screws, bolts or stronger with brackets (decking brackets?)?
Thanks in advance
David
dave9898 is offline   Reply With Quote
Old 07-25-2007, 09:30 PM   #2
Do you have photos?
redline is offline   Reply With Quote
Old 07-26-2007, 07:36 AM   #3
Ran into tech difficulties.
Unsure how to reduce file size small enough so that this site will accept the attachments. Using Acrobat I was able to reduce down to 19.9k but site only accepts 19k or smaller and cannot reduce further.
Do you know another way to reduce or can I e mail you directly?
More On This Topic
This is Ben Ingham with Expert Village talking about a walk out basement. However most of the building material that I will be using until I get the stud walls up and a exterior wall up and a roof over it could be expose to some weather without any... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
Hi! I'm Drew Finn and I am here for expertvillage.com. I am a professional home inspector and I am going to show you how to install a ceiling fan today. We've turned the power on and here's the final test; we've got power, it's running. What we are going... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. The next one that we are going to cover on this list is going to be the air barrier and all... Read More »
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
raising ceiling height, raftered at 8 and 10 already DoubleD07 Building & Construction 13 07-20-2007 08:05 PM
raising ceiling famtwp Building & Construction 10 05-30-2007 09:00 PM
raising ceiling strada23 Building & Construction 5 05-06-2007 11:12 PM
raising ceiling height during remodel marks Building & Construction 1 10-04-2006 02:58 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
