Old 12-21-2010, 06:51 PM   #1
Ceiling height
I'm building a pole barn home (2 story). Is a 7'"6" ceiling height ok for the first floor? I live in a very rural area so codes are not an issue here however I am worried about wether or not it will be functional.
Just "A" is offline   Reply With Quote
Old 12-21-2010, 07:08 PM   #2
Framing Contractor
Ceiling height
Why would you even consider a 7'6" and not 8'?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-21-2010, 07:21 PM   #3
the Musigician
DangerMouse's Avatar
Ceiling height
Functional? Sure! Easier? No way....
The whole idea behind 8' ceilings is you can buy 4'x8' sheets of materials that pop right on and framing studs come precut for 8' too.
It just makes it simpler, unless there's a good reason for your desire to go 7' 6"?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 12-21-2010, 08:16 PM   #4
Ceiling height
Hi
While your at it and as you do not have planning restrictioins why not consider a floor with a difference, be it ground or first floor - and go for say a 12ft ceiling height. If on the ground floor this would give an impressive and unexpected entrance, and space appeal!
Regards
GJ
hereslookingatU is offline   Reply With Quote
Old 12-21-2010, 08:20 PM   #5
Ceiling height
Initially we was going to do a 12' ceiling to give it a very open feel. However we have three daughters and are getting the whole we want our own rooms. Well we have already have the shell up and it is too late to make it taller. If I do 7'6" I can do two floors with the same ceiling height thus giving each there own rooms.
Old 12-21-2010, 08:27 PM   #6
Moderator
Ceiling height
Cruise around here: http://publicecodes.citation.com/ico...9_3_sec005.htm
At least build it to minimum safety code, as if receiving a "D" on a test......
Notice the safety glazing and egress for bedrooms, your daughters will thank you when they are older.
Gary
Clothes taking longer to dry?
Old 12-21-2010, 08:28 PM   #7
the Musigician
Ceiling height
If that's what makes the wife happy, you've already answered your own question. Po)
DM
Old 12-21-2010, 09:20 PM   #8
Ceiling height
Thank you so much for the reassurance I did not want to build this and later get the whole what the Fu$&? I was hoping not to get the you are a fool replies. Once again thank you, I'll post images as it goes along.
Tags
2 story, ceiling height, home, pole building
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Very, Very noticable ceiling height issue Nick DIY Drywall & Plaster 4 12-11-2010 11:38 AM
replacing a 7'6" ceiling for a Split-foyer home czellerhoff Building & Construction 1 10-16-2010 12:36 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Drop Ceiling Height jamiedolan Remodeling 7 10-22-2009 02:21 PM
