Old 02-06-2006, 10:27 PM   #1
Ceiling Fan Weight - new home
I have a new-construction home (closed in Oct) that's prewired for ceiling fans. I bought a fan that's ~50 lbs without a light kit. Intending on installing a light kit and then installing the fan, but I'm concerned about that weight being supported by the mount box. I'm pretty sure it's OK, but I also don't want the thing falling on my family. Any suggestions on the max weight that those things are designed to support?
dstinsman is offline   Reply With Quote
Old 02-07-2006, 09:05 AM   #2
Remodeler
MinConst's Avatar
I would ask your builder this question. He installed the boxes and should know the specs on them. It's only a phone call away.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 02-27-2006, 07:05 PM   #3
IF the contractor installed boxes designed for hanging ceiling fans you should be fine. A few things you can look for if you're not sure how to recognise a fan box: pre-wired for a fan, metal box (a lot of new construction uses plastic boxes except for fans) but you already had the right suggestion: call and ask! Or the boxes might be (should be) marked so look around on the inside with a flashlight . . .
For more info on installing ceiling fans, check:
http://www.ceiling-fans-n-more.com/c...stallation.php
ceilingfanrepair is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
