Old 08-07-2011, 09:47 AM   #1
Question
Ceiling Anchoring of Compression Poles
I'm installing a shelving system using floor-to-ceiling compression poles, with a slightly uneven forward-facing distribution of weight on the poles.
Here are the manufacturer instructions: http://rakks.com/pdfs/PC4Install.pdf
Here's what a finished system might look like: http://rakks.com/products/configurations_all.html (configuration B).
In my particular configuration, there's a desk surface that extends farter outwards from the poles.
As per the instructions, I need to screw the top of the compression poles into the ceiling (drywall, doesn't seem to be any studs where the poles lie), but I'm not sure what kind of anchors I should be using.
It seems like most of the weight and force should be held by the compression poles, and that there are two concerns regarding anchoring:
* Shearing force: top feet might slip forward and away from the wall
* Tension force: bottom feet might slip in and towards the wall, causing the top feet to pull out of the ceiling (seems like there'd be much less tension than there is shear stress).
The way that the compression pole feet are designed, I need to screw in the anchors/screws through the feet themselves, using #6 screws -- I'm not sure what type of screws/anchors I should be using here.
I also worry that screwing holes into the ceiling where the compression poles are placed will actually weaken the ceiling and could cause the compression poles to punch through -- anyone with more construction smarts than me know the answer to that one?
Thanks!
Last edited by planar; 08-07-2011 at 10:06 AM. Reason: Added a note regarding shear stress vs tension
planar is offline   Reply With Quote
Old 08-07-2011, 04:28 PM   #2
Attach the screw mechanism to a larger plate and attach that to the ceiling.
Or
Take a 4"x4" piece of wood and cut a hole in the middle for the screw device to nest in and screw the wooden plate to the ceiling.
You can route the edges or apply a shoe molding to ease the visual transition from the block to the ceiling.
I'd balance the weight side to side as well as possible or install the shelves as seen in the photos, weight to the wall.
Ron
B. Franklin 1759
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 01:31 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
