Ceiling Advice Needed.... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 12:34 AM   #1
ceiling advice needed....
Hello, I am building a room inside a room, a vocal booth, I need help with the ceiling, it cannot be attached to the existing room, only put on top of the walls. what kind of products/ or building techniques are available in the market to prevent the ceiling from having a "belly" in time... something that will help me build a strong ceiling. (sorry for the non professional language )
If someone can point me in the right direction Thank you!
Hila
Hila is offline   Reply With Quote
Old 03-24-2013, 01:30 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Hmm...we need some more info. What size room are you building? Your question sort of confuses me. Do you have any framing knowledge? To build a room inside a room wouldn't be much different than building a room itself. Probably use 2x4 framing for walls - although with it being a vocal booth maybe you'd want thicker walls not sure.
fetzer85 is offline   Reply With Quote
Old 03-24-2013, 01:46 AM   #3
Attach resilient channel to the old ceiling and attach the new ceiling to the bottom of the resilient channel. But it depends on what you mean by "it cannot be attached to the existing room." Look up the details on how to attach it properly.
Dorado is offline   Reply With Quote
Old 03-24-2013, 09:00 AM   #4
Rewards Points: 13,296
Just look up shed building plans, use 2 X 8's for the ceiling joist, and build it as if it was a flat roof.
Help needed with wiring a new ceiling fan/light switch DIYChallenged3 Electrical 1 12-01-2012 09:36 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 08:57 PM
Ceiling Fan Advice rlynch HVAC 13 08-30-2009 07:37 PM
Builder skipped ceiling joists in bonus room need advice minicus Carpentry 31 08-11-2008 11:44 PM
