Ceiling About To Go Up - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 08:33 PM   #1
Rewards Points: 91
ceiling about to go up
quick question - about to put my ceiling up, normal drywall, going on 24inch joists, for a bathroom - do I screw & glue, or just screw?
mmhendrie is offline   Reply With Quote
Old 03-18-2009, 08:45 PM   #2
Woody
Phuture's Avatar
you couls just screw it. with 24" oc joists you may want to consider 5/8" drywall. anything less may tend to sag in between the joists under humid conditions.
Phuture is offline   Reply With Quote
Old 03-18-2009, 08:50 PM   #3
Rewards Points: 91
live in Los Angeles - what's humidity!?
Old 03-18-2009, 08:57 PM   #4
Woody
Phuture's Avatar
i hear ya!
Old 03-18-2009, 08:59 PM   #5
Woody
Phuture's Avatar
what part of L.A.? my uncle owns a pizza joint in san pedro.
Old 03-18-2009, 09:14 PM   #6
Rewards Points: 91
further north of San Pedro - Culver City
Old 03-18-2009, 09:55 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
24" O.C.? I's say to add strapping at 16" OC. Then install 5/8" GWB. Glue and screw.
If it's a large ceiling, and your trusses are moving, that is a whole different installation.
- Build Well -
Old 03-19-2009, 10:29 AM   #8
Can you expand on this? I am drywalling a 24'x24' cathedral cieling (trusses, not rafters), they are 24" on center and I am using 5/8" drywall, 12 foot long peices.
Should I use screws and glue both? TIA
Ininkus is offline   Reply With Quote
Old 03-19-2009, 12:48 PM   #9
Drywall contractor
Rewards Points: 1,070
If you go with the strapping on 16" centers you can use 1/2" rock. You need 5/8" for 24" centers. Always use adhesive. Less fasteners necessary, thus fewer "pops".
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-19-2009, 02:42 PM   #10
Rewards Points: 91
what do you mean by pops?
Old 03-19-2009, 03:09 PM   #11
Drywall contractor
Maybe I should have phrased it less chance for ANY "pops" which happen when lumber "moves". Lumber expands/contracts during heating/cooling seasons. New lumber dries out and shrinks to some extent. This can cause fasteners to "protrude" back out of the stud slightly as they don't move with the lumber. Thus you get a nail/screw "pop". A common occurrence. You may not get any going into seasoned lumber. And humidity is still a factor in L.A. if you take a hot enough shower.....
Old 03-20-2009, 03:57 PM   #12
Rewards Points: 270
hmmm- maybe I can leverage that point - to feel a bit better about being a slow poke and taking forever on my project - the framing's been up for about a year and a half now - does that mean it's seasoned and possibly fewer pops when the drywall goes up?
feel free to throw me a bone here
rtoni is offline   Reply With Quote
Old 03-20-2009, 05:46 PM   #13
Drywall contractor
You're pretty safe as far as "shrinkage" goes I think. Lumber still "moves" during "seasonal" changes in heating and cooling (and at times for other unforseen reasons such as settling). I still recommend using adhesive. If you have a wall in your house that you know is not glued, bang on it with the heel of your fist. You can hear the board "rattle" against the studs (interior non-insulated wall). The same wall with glue won't do that. If you ever have to patch a wall that has been glued, when you tear out the piece to be patched, the backing paper on the rock will still be on the stud when you pull the damaged piece out. The likelyhood of "seasonal" lumber movement causing fasteners to "pop" is greatly diminished with adhesive....
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
