Old 01-31-2012, 08:39 PM   #1
castroball5
Cedar vs. pt pine
I'm planning on building a deck to go out by my pool. I was gonna use pt for the posts and joists and cedar for the actual decking. What do u recommend? Pt pine or cedar decking? Which will last longer? I was planning on sealing the cedar decking. Any advice is appreciated!
castroball5 is offline   Reply With Quote
Old 01-31-2012, 08:44 PM   #2
Cedar vs. pt pine
How long do you want it to last? Clorine is hard on both of them. Wantt it to last far longer, never need seailing, no slivers, no cupping, no cracks then go with vinly coated composite.
Old 01-31-2012, 09:19 PM   #3
Cedar vs. pt pine
To be honest, I might go with composite...especially around a pool. However, if that is not in your budget, I wouldn't waste the extra $ on cedar. It will gray VERY fast, and unless you like that look, it probably isn't worth it.
The PT that you get now isn't dark green like it used to be so it looks more natural and can be stained to be just about any color you'd like.
I put on a PT deck about 5 years ago and used Cabot natural stain. I've had friends who are general contractors ask if it was cedar....FWIW.
cibula11 is offline   Reply With Quote
Old 01-31-2012, 09:24 PM   #4
castroball5
Cedar vs. pt pine
It's not going to be directly next to the pool and it's a salt water pool. Don't know if that's worse or not. I don't feel like shelling out $$ on composite, I just don't want the pt to "check" ya know. Do u think stain will keep it from checking? Don't u have to wait for pt to "dry out" before u stain it?
Old 01-31-2012, 09:39 PM   #5
robertcdf's Avatar
Cedar vs. pt pine
Environments and locations play such a huge role, in MY market cedar is 8-10 cents more than PT... Kind of a no brainer there, PT here is absolute junk, even if you stain it on a daily basis it still looks like garbage in 3 months.
robertcdf is offline   Reply With Quote
The Following User Says Thank You to robertcdf For This Useful Post:
kwikfishron (01-31-2012)
Old 01-31-2012, 09:56 PM   #6
MarginallyQualified
Cedar vs. pt pine
The key to success with using PT is three fold:
how well you pick your boards, how well you install them and how well you keep them up.
Make it *easy* to clean up the surface over the years... even sanding it if needed.
http://www.deckmagazine.com/article/46.html <-- lots of hdwr ideas.
http://www.kregtool.com/Deck-Jig-Prodview.html
TarheelTerp is online now   Reply With Quote
Old 01-31-2012, 10:53 PM   #7
Cedar vs. pt pine
Never had a problem with pt..., but my friend has cedar that looks like crap...it's all in how you maintain it. Yearly staining/sealing for both.
Old 01-31-2012, 11:36 PM   #8
castroball5
Cedar vs. pt pine
Thanks all. One more thing, with pt how long do I have to wait before staining/sealing?
Old 01-31-2012, 11:42 PM   #9
Cedar vs. pt pine
Depends on the weather and humidy. In GA it would be best to wait a min. of 3 months.
If you can find a dealer that stocks Thompsonized wood it can be stained as soon as it's installed. It's kiln dryed after treatment.
Old 02-01-2012, 01:17 AM   #10
sdsester's Avatar
Cedar vs. pt pine
Don't go with Thompson's. It is a liquid wax product and will just cause you problems. If you are lucky you will only get a season out of it and any attempts and applying a semi-transparent stain will be blotchy because of the wax.
As mentioned, you should plan on a semi-transparent stain or sealer annually. Cedar will give you a level of insect protection you will not get with PT pine. Of course I practiced landscape design in redwood country so my bias goes that direction if availed you. Probably not where you are.
sdsester is offline   Reply With Quote
Old 02-01-2012, 09:01 AM   #11
Cedar vs. pt pine
I live in Iowa and I put my deck on in may and waited till oct to stain. U need 3 solid days of sunshine and warm weather.
Old 02-01-2012, 09:31 AM   #12
Cedar vs. pt pine
Tomsonized wood not Tomson wood treating products, which I know are junk.
It comes with a life time warrenty and it's treaded to the core not just the surface.
Old 02-01-2012, 09:59 PM   #13
Moderator
Cedar vs. pt pine
If you go with composite, leave 6" min.of airspace under it to prevent mold/mildew. The more plastic content- the less mold, Trex is 50%....
If you go with p.t.;
5 days to weather and dry: http://www.cabotstain.com/products/p...od-Primer.html
2 weeks to dry: http://www.inspectapedia.com/BestPra...s_Exterior.htm
The water bead test; http://www.sherwin-williams.com/do_i.../staining_faq/
http://www.ppgpittsburghpaints.com/f...wers/index.htm
http://www.olympic.com/stain/do_it_y...#waterproofing
http://www.greatsouthernwood.com/products/buildingtips
And 3 weeks or longer, too bad; http://bct.eco.umass.edu/publication...ns-about-wood/
Gary
Clothes taking longer to dry?
Tags
cedar, deck, decking
price of douglas fir vs pine and cedar? ole Building & Construction 3 04-24-2011 11:45 AM
Oak floor over pine? bhry Flooring 1 11-30-2010 10:30 PM
Stain for Deck teamcanada Painting 15 06-27-2010 09:49 PM
cedar deck looks like crap silky Painting 16 05-02-2009 11:42 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
