Cedar Vs Fir - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 11:57 AM   #1
Cedar vs Fir
I am building a new fence and am looking at cedar and fir blanks. Fir is less expensive, any idea around durabiltiy and how it takes stain??
joek is offline   Reply With Quote
Old 07-14-2008, 07:16 PM   #2
Rewards Points: 562
fir is basicly untreated lumber you frame with(did that make sense??) Cedar has alot of natural decay resistance,,I am SURE cedar would outlast fir 2-3 times over,,,fir will rot pretty darn quickly unless painted ALOT!!!
IF you possibly can,,,select the cedar,,it will help keep your honey-do projects down. (I always HATE replacing things for the 'second' time)
4just1don is offline   Reply With Quote
Old 07-14-2008, 09:31 PM   #3
Registered User
Termite's Avatar
Fir would work for a fence only if it is properly primed, painted, and maintained. I would strongly advocate for Cedar.
Replacing Asphalt w/ Cedar Shingle pbehnke Roofing/Siding 1 05-06-2008 02:28 PM
Laminate Flooring and a Cedar Closet StevenS Flooring 5 03-17-2008 12:28 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
