Cedar Siding My Best Option? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2008, 09:31 AM   #1
Currently living in Japan
Cedar siding my best option?
Hi everyone.
I'm a building amateur, but I can learn quickly. So I'm looking at redoing the outside of our house myself, or at least some of it.
We have an old 2-story house here in Japan. The exterior is a kind of concrete made on a wire mesh frame in sections. The roof is made from large ceramic tiles. And the windows/doors are all aluminum frame cheapies.
So I was trying to decide a cheap, attractive way to make it look like a new house. Vinyl siding is popular here, but it's very expensive, and I think the house will still look kind of cheap. I was thinking cedar siding would look really good, and kind of match the image we are going for. If possible, we could also cover the roof and window frames with cedar.
Since the house currently is technically OK, would it be possible to make a very thin, cheap, purely cosmetic exterior reform using cedar? I was thinking of just putting it over top all the old walls and roof, as is. Then it wouldn't even need to be weather proof. Is it possible? What would be the best way to attach it all?
If cedar is difficult, how about another type of wood?
Is this project totally impossible?
Thanks for any help!
TheNiceGuy is offline   Reply With Quote
Old 09-11-2008, 03:02 PM   #2
Any ideas?
Old 09-11-2008, 04:01 PM   #3
Drywall contractor
Rewards Points: 1,070
Nothing's impossible....perhaps impractical. The problem is going to be fastening the siding. You'd have to fasten furring strips over the concrete in order to nail on your siding. You could trim windows and doors with cedar. I don't think cedar over a tile roof is going to work (though not my area of expertise). Have you priced cedar?? It's way more than vinyl here.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-11-2008, 09:27 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This is kind of a difficult question to answer. Exterior materials on homes, is generally gauged per climate and region. That also goes for how it is installed, or the method of installation.
Local codes and general building practice also affects the choice of siding, and it's method of attachment.
You would really need to include some more details, and pictures, in order to get more feedback. Example: in my region, cedar is not installed on roofs.
- Build Well -
Old 09-12-2008, 11:24 AM   #5
Drywall contractor
Good point about climate. Atlanta has a fairly temperate climate and cedar shake roofs are pretty rare.
Old 09-13-2008, 03:05 PM   #6
Evershield vs. Enduracryl
I too live in the northwest. My house is painted cedar with some blistering and cracking in the exterior paint. I am in the process of getting bids for painting the exterior and have received so many different opinions about which Dunn Edwards paint to use due to cracking and blistering.
Does anyone know which Dunn Edward exterior paint I should use "Evershield (flat) vs. Enduracryl (low sheen)? And how long paint should last?
lundybar is offline   Reply With Quote
Old 09-14-2008, 04:26 PM   #7
Thanks for the guides. I'll try to get a translator and sit down with a local contractor I know. I'll let you know what I find out.
The good side is that building regulations, or at least enforcment, are very lax here where renovating on an existing structure.
Old 09-14-2008, 05:14 PM   #8
Registered User
Termite's Avatar
It may be possible to use cedar where you're at, but you shouldn't consider it ok to allow water behind it. It would need to be installed in a weatherproof manner. If it isn't properly sealed up and water can routinely get behind it, it won't last nearly as long. Agreed, you'll have to use furring strips to devise a method of attachment for the lap siding. If you're thinking cedar shakes, you'll need furring strips as well as sheathing.
Old 09-15-2008, 07:44 AM   #9
Drywall contractor
Post some before and after pics if you get a chance. Interested to see how it turns out.
Exterior Cedar Siding - Products & Procedures? chitown55 Painting 9 09-15-2007 06:54 AM
revitalizing cedar siding Fat b Painting 1 04-30-2007 02:29 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
