Cedar Siding Alternatives For Small Reveal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 09:21 PM   #1
Cedar Siding Alternatives for Small Reveal
Hey Everyone,
My house has cedar siding with a 2.5 to 3 inch reveal. When replacing areas of siding (we removed a couple windows etc), I am using cedar siding and hand nailing before painting.
My question are as follows:
1. Is there any other siding material besides vinyl that can be easily installed with a ~3 inch reveal? Is anyone out there doing this? I guess I am not opposed to vinyl, but I don't prefer the look and as I am not interested in doing the whole house, I am worried different fade patterns will ultimately be a problem.
2. If I stick with wood, is anone using a nail gun to face nail cedar clapboard siding that is only 3.5 inches wide (like what I am using)? I am not aware of a nail gun that carries the right nails for this application. They all seem to be geared towards cement or some other type of siding.
Thanks for the input. I would like to either continue using wood but speed it up a little or switch to a siding that will need less maintenance(even if it takes more time up front).
John
jburr827 is offline   Reply With Quote
Old 05-17-2011, 05:59 AM   #2
kwikfishron's Avatar
Rewards Points: 218
Welcome to the forum.
I wouldn’t use vinyl siding to patch up cedar. They do make nail guns for siding (coil nailer) but I never use them on face nailed cedar.
kwikfishron is online now   Reply With Quote
Old 05-17-2011, 08:02 AM   #3
Rewards Points: 2,238
I've used the air guns, on Cedar, which {kwikfishron} speaks of - 2 times.
The result being: over-drive or under-drive many of the nails -
time spent taking care of that.
Had to go back, within a year or two, and replace split pieces -
over-driven (probably).
I wouldn't use them again!
It's a good idea to pre-drill the nails, on the ends or near "knots".
Also, back prime/stain the Cedar before you install it - ends, also.
rossfingal
rossfingal is offline   Reply With Quote
Tags
cedar , reveal , siding
Solid Stain on Cedar Siding Researcher Painting 1 08-08-2010 11:11 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 10:10 PM
Installing fiber cement siding over existing cedar siding heron Remodeling 3 07-25-2009 12:17 AM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
