Cedar Shakes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 12:55 PM   #1
Rewards Points: 109
cedar shakes
I am painting my house right now and the cedar shakes come right down to the top of the window flashing. Should I leave that small gap between the flashing and the bottom of the shake or run a bead of caulk? I'm thinking it should be left without the caulk.
hitmehhh is offline   Reply With Quote
Old 08-29-2010, 01:12 PM   #2
kwikfishron's Avatar
Rewards Points: 394
There should be a gap between the siding and the flashing.
Do Not Caulk that gap.
The gap above the flashing is there so that if any water gets behind the siding from above it has place to escape.
kwikfishron is online now   Reply With Quote
Old 08-29-2010, 01:14 PM   #3
Civil Engineer
Rewards Points: 4,698
Not quite sure I follow the post. I also have cedar shakes. On my windows, the flashing on top of the windows (the drip cap) is a Z shaped piece of copper, about 8 inches tall, that covers the top of the window cap and extends about 5 or six inches up the wall. The shakes come down approximately to the window cap, which means they cover about 5 or six inches of flashing. There is a very small gap, like you said, between the bottom of the shakes and the window cap, which I have not caulked. Any water that gets behind the shakes works its way down the wall, and comes out that gap, onto the drip cap, and off the drip cap, so caulking the gap would prevent moisture from leaving.
Daniel Holzman is online now   Reply With Quote
Old 08-29-2010, 01:24 PM   #4
Rewards Points: 109
Thanks for the quick replies
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
cedar shakes by crane or cedar impressions elva Building & Construction 16 06-20-2010 07:51 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing/Siding 5 10-12-2006 05:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
