Old 08-08-2006, 09:47 PM   #1
cedar posts
What is the best way to set cedar deck posts in the ground?
ptbauc is offline   Reply With Quote
Old 08-10-2006, 05:53 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
cedar posts
Hi,
I'm not sure what the building codes are in your area, but in our parts:
To properly anchor a deck post, no matter if it's PT or Cedar -
It must be anchored to a concrete footing. If you live in an area of frost, then the concrete footing must extend 4' down below grade. Lately most building depts around here want 12" diameter footings. The Post must then be anchored to the footing using a bolt and bracket system.
- Build Well -
Cedar or PT Fence Posts??? C&D Landscaping & Lawn Care 15 04-08-2008 11:27 PM
Deck Posts question flyultralite Building & Construction 1 06-23-2007 10:18 AM
cedar shakes: nails vs staples.... MichaelinOmaha Roofing 5 10-12-2006 06:22 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 07:46 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
