Caulking Vinyl Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 08:34 PM   #1
Rewards Points: 83
caulking vinyl siding?
Hi,
For those siding experts out there....
Should the builder have caulked the vinyl siding where it meets the windows?
He didn't...saying that the window was caulked inplace, but the vinyl siding will move do to temperature changes, so the tightness (and why it's not caulked) doesn't matter since the vinyl siding will expand contract.
Also, should I caulk the bottom row of the siding where the foundation starts to help keep insect out, or again, should this be left as is so any moisture that gets behind the siding is free to drain out.
There is a tyvek wrap if that matters either way.
Thanks again for all the help
bergerdude is offline   Reply With Quote
Old 03-26-2011, 06:21 AM   #2
Rewards Points: 2,240
As far as the siding goes - most vinyl siding has "weep holes" in the bottom
of the panels to drain any moisture out.
The bottom course of siding is probably clipped into a "Starter Strip" -
continuous - so caulk is probably not required.
If you're talking about caulking between the siding and the "J" channel (that
the siding ends in) - probably not.
Between the "J" channel and the window/door trim - yes, you can do that.
Use "Solar Seal", "Quad", or equivalent - not Silicone.
Regards!
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
bergerdude (03-26-2011)
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
