Caulking Project - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2010, 08:04 AM   #1
Rewards Points: 20
Caulking project
Several years ago I built my on house. I went and glazed 10 sliding glass
door replacement panels into some frame work. Now its time to think about
caulking them. The only problem is I live in Michigan. The tube says do not use when the temperature is below 40 F. Is this a problem. Do contractors wait until the weather brake before using caulk. I guess i could wait until
spring, but id rather get it done before the oil prices go up another cent.
v6turboman is offline   Reply With Quote
Old 11-25-2010, 08:54 AM   #2
the Musigician
DangerMouse's Avatar
There's some warmer weather ahead, just do the job around 9:00 or 10:00 so it can stay warm most of the day as it sets up. As long as it's above freezing, you should be OK.
DM
Old 11-25-2010, 09:08 AM   #3
Rewards Points: 1,642
Supposedly, Dap's 3.0 can be applied in temps to -35 degrees F:
http://www.dap.com/3point0/about.html
Here are the facts about DAP 3.0™ Advanced Sealants:
  • Permanently waterproof and weatherproof seal.
  • Cured sealant that's mold and mildew resistant.
  • Outstanding flexibility and adhesion to a wide range of substrates without cracking.
  • Superior paintability.
  • Easier to tool and less stringy than premium silicone.
  • Extreme weather and temperature application range for outdoor applications: -35F to
    140F (White), -35F to 120F (Crystal Clear).
  • Low odor and low VOC content.
  • Lifetime guarantee
bob22 is offline   Reply With Quote
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
My basement project - a 2 year project. HABSFAN2006 Project Showcase 14 07-12-2009 09:30 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 08:33 AM
