Caulking Cedar Siding Gaps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 03:57 PM   #1
Rewards Points: 1,062
Question
caulking cedar siding gaps
hi, i was curious about product recommendations for caulking imperfections in cedar siding, as can be seen in the picture. perhaps some wood-colored caulk, if anyone knows of any.
thanks
Old 06-28-2011, 04:07 PM   #2
Rewards Points: 1,588
Those are some gaps. Trouble with caulk (colored or not) is what will the cedar siding color be in the future? If you go natural, then one color. If you stain it, another. Personally, I'd put new boards on and then decide on caulk color. If the gaps are smaller, so will the likelihood of the caulk color being an issue.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
amakarevic (06-28-2011)
Old 06-28-2011, 04:16 PM   #3
it's OK, i'm not being nit picky. being in the ballpark is fine, doesn't have to be 100%. it is just a shed. i plan to paint it once the original color fades.
Old 06-28-2011, 04:18 PM   #4
Then pick a 25-yr/lifetime caulk (paintable) that comes in a color close to what you will paint it.
Old 06-28-2011, 04:26 PM   #5
kwikfishron's Avatar
Rewards Points: 586
Vulkem, Color- Buff
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 06-28-2011, 09:13 PM   #6
Question
would it be this one:
http://www.amazon.com/Buff-Tremco-Vu.../dp/B000WU26E6
thanks
Old 06-29-2011, 04:31 AM   #7
Rewards Points: 586
Originally Posted by amakarevic View Post
Thatís the stuff but $9.25 a tube is out of line.
It should be in the $5-6 range. Your lumber yard, hardware, or box store should stock it.
amakarevic (06-29-2011)
Old 06-29-2011, 01:10 PM   #8
one more question: can i use the same product for sealing the unused hole space when i run wire or pipe in or out of the shed or would this not be thick enough?
Old 06-29-2011, 01:51 PM   #9
Rewards Points: 5,336
You can eliminate this in the future by squaring off the ends before you measure the lengths to be cut.
Ron
B. Franklin 1759
Old 06-29-2011, 01:53 PM   #10
Question
squaring off the ends?
Old 06-29-2011, 02:32 PM   #11
Putting the wood in the miter saw set to 90 degrees and cutting off the out of square rough cut end pieces.
This is a standard building practice to start out with a square end.
Ron
B. Franklin 1759
Old 06-29-2011, 04:06 PM   #12
Rewards Points: 586
yes you can.
Old 06-29-2011, 04:13 PM   #13
Originally Posted by kwikfishron View Post
yes you can.
thanks... you can keep the "change"
Tags
caulking
Cedar Siding Alternatives for Small Reveal jburr827 Building & Construction 2 05-17-2011 07:02 AM
Solid Stain on Cedar Siding Researcher Painting 1 08-08-2010 10:11 PM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
