Caulking Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2009, 01:12 PM   #1
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Caulking Brick
I've caulked before, tubs etc. so I'm not a total newbie to caulking, but it's time to do the windows. Actually it was time last fall but lets not go there.
We have a brick house with aluminum windows. I was wondering if anyone had any suggestions or tips to make caulking brick a little easier. I know caulk should be applied to a clean surface but is there anything I can or should use on the brick besides a stiff brush? Any suggestions on what type of caulk to use. And lastly, we have three second floor windows. Is it a major no-no to do these from the inside (also brick)?
Old 02-13-2009, 01:59 PM   #2
Remodeling Contractor
You want a urethane caulk. And the joint should be fairly wide to assure a good bond. 3/8" Tool with a back of a spoon. Do not tell your wife you took it from the kitchen. And yes no reason not to caulk the inside also. Clean first with windex will work also spray on joint prior to tooling. Caulk only about three feet then tool.
Old 02-13-2009, 09:47 PM   #3
Stuck in the 70's
Thanks for the help Bob. I was thinking a smaller bead would make less of a potential mess but that makes sense.
Except about not telling the wife.
That part's a bit difficult.
I is the wife.
Old 02-13-2009, 11:19 PM   #4
Registered User
Termite's Avatar
Note that Bob used the word "also" when referring to caulking the second floor windows...Meaning in addition to the outside. There's no way around doing that unfortunately.
Old 02-14-2009, 06:46 AM   #5
okay I was using two answers to two questions. But of course you need to caulk the outside as a priority. In most all other cases except maybe siding the caulking joint would be small. This is the exception here.
Old 02-14-2009, 06:56 AM   #6
i like to use painters tape on the windows and the brick prior to caulking. Takes an extra minute but you'll see the difference right away compared to windows that arent taped off first.
II Weeks is offline   Reply With Quote
Old 02-14-2009, 11:34 AM   #7
Stuck in the 70's
Thanks everyone.
That is what I was afraid of (and needed to know). The sloping ground, A/C unit, and a couple of "greenhouse" windows that stick out on the first floor are going to make that a challenge.
Old 02-14-2009, 03:48 PM   #8
Man of many hats
wrangler's Avatar
Rewards Points: 354
I prefer to use a high viscosity silicone, it is easier to tool(smooth) than home center silicones and fills the larger voids common in most brick applications. I have found that Novaflex by Novagard works well,(it has the consistancy of peanut butter vs. mayonaise) but it is not available in home centers. You can find it at many siding and window distributors though. If the house in your avatar is the house in question, it does not appear that it would be too difficult to seal the outside of the windows from a 24' extension ladder, but the outside IS very important. If the garden windows wont allow you to do this, at least try to caulk as much of the outside 2nd floor windows as you can. You can do a major portion of this from inside the house... raise the window, remove the screen and reach as far as you SAFELY can. I have had to sit on the window sills of open windows to do seal units 10 floors high, but I would NOT recommend this for the average DIYer, but when you are installing windows in a condo, you do what you have to do. The majority of rain will hot the lower 2/3 of your window, so at least getting that high will help if the current caulking had failed. Keep plenty of rags/paper towels on hand so that you can complete each window in one shot. I definitely recommend having someone there to help... for both your safety and to hand things as needed.
Man of many hats
wrangler is offline   Reply With Quote
Old 02-15-2009, 11:51 AM   #9
Stuck in the 70's
Yes, the avatar is the house.
I've been up there on an extension ladder before, cleaning out the gutters. Not my favorite chore.
I guess I'll just do the bottom and sides reaching out from inside to protect from water, and then do the whole thing on the inside for drafts. At least I don't have to worry about removing the old caulk, there is none!
Thanks again all.
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
