Caulk, Silicone And Sealant Are They The Same Or Different? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 03:11 PM   #1
ask
Caulk, Silicone and Sealant Are they the same or different?
Having seen manufacturer uses different product name such as DAP Sealant, GE Silicone and some are just called caulk. They all are in the tubes and applied to gap and joints. Can you explain weather they are the same or different and how to select the right material?
ask is offline   Reply With Quote
Old 05-16-2011, 03:20 PM   #2
Civil Engineer
Rewards Points: 4,942
Silicone is a term used for a variety of products with the following chemistry:
A durable synthetic resin with a structure based on chains of alternate silicon and oxygen atoms, with organic groups attached to the silicon atoms.
Sealant is a term based on the verb to seal, meaning a product designed to keep out a fluid, usually water.
Caulk as a noun mean A waterproof filler and sealant, used in building work and repairs. Caulk as a very refers to the installation of caulk.
So caulk and sealant appear to be essentially identical, whereas silicone is a type of sealant or caulk.
How to select the right material. Read the labels very carefully, there are thousands of sealants and caulks out there, they typically are designed for different applications, they have different warranties, different lifespan, different costs, and different application techniques. Only the manufacturer can tell you what type of application they will work on, and sometimes the manufacturers do not tell you the whole story.
Old 05-16-2011, 04:59 PM   #3
Rewards Points: 4,796
never thought about that but it is confusing, isn't it,,, generally speaking, most sealants are installed over a bondbreaker meaning they only adhere on either side of something ( pavement joint, building stress relief jnts ),,, caulks adhere on all surfaces but do not weather the expansion/contraction stress as well.
Old 05-16-2011, 11:45 PM   #4
Registered User
Rewards Points: 526
Don't use a caulk when you really need a flashing or backer rod and caulk; http://www.fpl.fs.fed.us/documnts/fplgtr/fpl_gtr169.pdf
Gary
Old 05-18-2011, 06:33 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Sealant and Caulk are interchangable terms for the most part. As stated, silicone happens to be the base material for one type of caulk/sealant, as are urethanes, latex rubber, butyl, poly-sulphides and a few other compounds. It is important to select the right caulk for the material being sealed and to create a joint that works with the properties of the material and the caulk. Here is a link that will show some typical joints.
http://www.masterwall.com/files/mw14...lantdesign.pdf
Tags
caulk , silicone and sealant
Painting over silicone caulk?? jschack Painting 34 06-15-2013 04:33 AM
silicone sealant has turned orange bobbysgirl Building & Construction 1 11-26-2010 11:00 AM
Silicone sealant RSDelacruz Kitchen & Bath Remodeling 1 08-01-2010 02:03 PM
Removal of Uncured (still soft) silicone sealant Hardy Building & Construction 2 01-23-2010 06:54 AM
How to seal my attic access - airtight? akoch General DIY Discussions 4 09-08-2008 08:03 PM
