Caulk At Bottom Of Column Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 03:35 PM   #1
Caulk at Bottom of Column Post
Hi Folks:
Need your advice and recommendations.
Yesterday I was painting 3 supporting columns that are under the roof of my front entry. The columns are 4x4s and are exposed to the environment. Although it is under cover, at times during heavy rains the inteface between the bottom of the column and the concrete floor is wet. It is not soaking wet but visibly wet. When the rains stops it takes about 1/2 to full day to dry (visually).
My friend came by and suggested after the painting is dry to apply a bead of caukling along the 4 sides at the bottom interface to prevent water from getting under the column. The column is in good shape and for all I know it is original to the home (60 years old). Would you do what my friend suggested? I am thinking the opposite that I should not caulk it because any slight amount of moisture trapped under the column will sit there and cause greater damage to the bottom.
Thank you
Shuriko is offline   Reply With Quote
Old 07-02-2012, 03:41 PM   #2
For some reason this post was duplciated. Can the moderator please omit it?
Thank you
Old 07-02-2012, 03:45 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
would be better if the post bottom was elevated,but i agree with you,easy in/ easy out
caulking would most likely fail and become an eye sore anyway
Tom Struble is offline   Reply With Quote
Old 07-02-2012, 04:10 PM   #4
My thoughts exactly....easier to dry out if left untouched. Unfortunately unable to elevate without doing much more then I want to at the moment.
I am not too worried about the looks because the bead would be small and the most folks walk right past the column without thinking twice about it.
Thanks for your input.
Old 07-02-2012, 04:13 PM   #5
Rewards Points: 12,802
I'm very surprized those post are not rotted out already.
Never use caulking there.
Old 07-02-2012, 06:39 PM   #6
I assume the posts are original but I have no way of verifying. The posts looked and feel in solid condition. Regardless as you suggested cauking is not advisable. Thank you.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 03:50 PM
Post problems WillK Building & Construction 8 03-28-2011 07:16 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
wooden basement post rotten on bottom truckinkat Building & Construction 1 09-29-2008 06:35 AM
