Caulk At Bottom Of Column Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 03:33 PM   #1
Caulk at Bottom of Column Post
Hi Folks:
Need your advice and recommendations.
Yesterday I was painting 3 supporting columns that are under the roof of my front entry. The columns are 4x4s and are exposed to the environment. Although it is under cover, at times during heavy rains the inteface between the bottom of the column and the concrete floor is wet. It is not soaking wet but visibly wet. When the rains stops it takes about 1/2 to full day to dry (visually).
My friend came by and suggested after the painting is dry to apply a bead of caukling along the 4 sides at the bottom interface to prevent water from getting under the column. The column is in good shape and for all I know it is original to the home (60 years old). Would you do what my friend suggested? I am thinking the opposite that I should not caulk it because any slight amount of moisture trapped under the column will sit there and cause greater damage to the bottom.
Shuriko is offline   Reply With Quote
Old 07-02-2012, 05:54 PM   #2
Rewards Points: 502
If the post is actually set in the concrete, caulking it probably won't make much difference either way. If its OK after all these years, why change anything?
tony.g is offline   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 03:50 PM
Post problems WillK Building & Construction 8 03-28-2011 07:16 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
wooden basement post rotten on bottom truckinkat Building & Construction 1 09-29-2008 06:35 AM
