Caulk For Below Ground - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 11:52 PM   #1
Rewards Points: 462
Caulk for below ground
Hello all!
I installed some PVC electrical conduit that exits the foundation of my house in a spot that will be below ground once the top soil is brought in (new construction).
I'm looking for a caulk that is rated for below ground. I didn't see anything at the home center.
Is this something I can buy locally or would it be a specialty item?
Thanks for your help.
Richo is offline   Reply With Quote
Old 05-29-2011, 02:19 AM   #2
Rewards Points: 1,092
Hard to believe silicone or any of the various butyl rubber caulks would not work. This may be worth a look. Ok, the chick was cute; what can I say?
http://www.bestmaterials.com/caulk_sealants.aspx
Old 05-29-2011, 07:07 AM   #3
Too Short? Cut it Again!
Yup, silicone should do just fine. Get a tube and caulk gun, not those silly squeeze tube things. Your other option would be an injected epoxy if there are any structural issues associated with the hole in the wall you need to address.
http://www.abatron.com
And jklingel, she was rather cute.
Old 05-29-2011, 09:50 AM   #4
Rewards Points: 462
Well, I had checked the silicone at the home center, the stuff that says "waterproof" but it also says not suitable for underwater use, so I would assume that it would not be suitable for underground either, being that wet ground may have the same effect.
I had been discussing this conduit installation on the electrical forum and one of the guys there said not to use standard outdoor caulk, but he didn't say what I should use.
The part where the conduit exits the foundation is actually through wood and not concrete, so any water entry into the building could cause more damage than just a little water coming in the basement.
Yeah, the girl is cute. They know what sells their product
Old 05-29-2011, 12:45 PM   #5
Hopefully your soil does not have 100 percent water content? I still think silicon would work just fine for this. Or as mentioned, go for an epoxy caulk if you are really worried.
You mentioned part of this involves a wood hole? That wood is treated if it is to be buried I hope.
Old 05-29-2011, 01:30 PM   #6
Rewards Points: 462
I don't know about the properties of the wood. Appears to be LVL, but it has some kind of heavy gray plastic barrier around it, apparently meant to mimic the look of concrete foundation. It's a flush entry home so the joists actually sit below grade but I would have to believe that the builder did it correctly to protect the wood.
Normally the top soil is supposed to go almost to the bottom of the siding but a rock bed with plantings is going to go in this section. Perhaps the landscapers can keep the top soil below the conduit and mound the rock bed over the pipe to hide it. That way I can just use the silicone and not worry about ground contact.
Old 05-29-2011, 01:45 PM   #7
kwikfishron's Avatar
Rewards Points: 86
The top soil shouldn’t come within 6” of the siding. I’d caulk that with a polyurethane caulk like Vulkem or Quad. You can get them both in grey.
kwikfishron is online now   Reply With Quote
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 03:01 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 08:03 AM
