Which Caulk? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-14-2007, 07:51 AM   #1
Landscape contractor
which caulk?
I've got a job that has a grate or trough drain along the side of a garage and it's not butted up against the brick wall very well, so water is getting into the garage from behind it. I used a silicon rubber caulk earlier in the year and now it's coming detached from the drain which is grey pvc. Our temps are in the 20-30's right now. Any suggestions on what might work better.
timber is offline   Reply With Quote
Old 12-15-2007, 07:43 PM   #2
Sonneborn NP1 is a urethane expansion joint sealant that might work for you. It holds to brick and cement pretty tenaciously, but if you are having movement due to frost, you likely won't get anything to hold permanently.
Instead of running a gigantic bead, you'd use backer rod to fill the space, and use the sealant to cover the backer rod.
XSleeper is offline   Reply With Quote
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 06:32 PM
Bathtub Caulk billinak Remodeling 17 05-27-2007 08:34 AM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 08:45 PM
Caulk over grout? Fulan Flooring 1 11-03-2006 07:44 PM
