Cathedral Ceiling Modification - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 10:54 AM   #1
Rewards Points: 127
(not sure if this is the right forum but im sure there is a few contractors on here...) We are currently looking at a house plan that has 3 bedrooms upstairs, one situated directly over the livingroom. Were thinking of modifying the plan by eliminating that one room to open up the living room and add cathedral ceilings. My question is, would the cost saving associated with removing the one room (drywall, ducts, electrical, flooring etc.) offset the cost of the more expensive joists needed for cathedral ceilings? What are some other financial pros/cons of doing this, (higher heating costs? lower property taxes due to reduced sqr footage, etc.?) -thanks
wilyum is offline   Reply With Quote
Old 06-24-2009, 04:11 PM   #2
Rewards Points: 5,336
You would need to speak to the local tax assessment office and the builder.
Ron
Old 06-24-2009, 05:19 PM   #3
Generally eliminating a bedroom could reduce your house value
But adding a cathedral ceiling in the main room could bring that value back
So tax value may or may not go down
Usually you need to appeal (wording ?) the tax value to get it reduced
Were you heating the bedroom you are eliminating?
Will the new cathedral room include all of the prior room?
Or will the new ceiling be lower then the old ceiling?
Is the thermostat in the room that will have the new cathedral ceiling?
I doubt you will recoup the cost of the renovation in lower taxes
It will probably be a lot of work to convert this
Old 06-24-2009, 08:46 PM   #4
Rewards Points: 127
Q. Were you heating the bedroom you are eliminating?
A. Actually the house isnt built I was just referring to changing the house plan, by eliminating the room would the cost be around the same when it comes time to build?
Q. Will the new cathedral room include all of the prior room?
A. The room is exactly the same size as the livingroom, same dimensions, directly on top.
Q. Or will the new ceiling be lower then the old ceiling?
A. I guess the ceiling would be the same height, just that the ceiling now wont have a bedroom under it but a living room.
Q. Is the thermostat in the room that will have the new cathedral ceiling? A. im going to say yes, might have different zones.
again im just wondering which of the two plans will cost more, to build with a bedroom above the livingroom or no bedroom and cathedral ceilings instead.
Old 06-24-2009, 08:56 PM   #5
It should cost less to build without the extra room
Insulating Cathedral Ceiling cholliha Roofing/Siding 3 11-25-2008 06:43 PM
inulation above cathedral ceiling LanterDan Building & Construction 14 06-11-2008 02:57 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 10:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
