Cathedral Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 08:52 AM   #1
cathedral ceiling
What do you think about using 2x10 rafters for cathedral ceiling with a horizontial span of 18'6" and a length of approximatly 26' from ridge to outside wall? What is the max size insulation for this and still have air gap to prevent moisture? Thanks for any replies
dvd1 is offline   Reply With Quote
Old 09-22-2009, 08:56 AM   #2
Registered User
Termite's Avatar
#2 Doug Fir can easily make that span.
As for insulation, you can easily fur the rafters down with 2x2's or 2x4's to gain extra insulation depth. That's very common.
Old 09-22-2009, 09:07 AM   #3
Thanks for the reply, most of the lumber we can get in this area is Southern Yellow Pine. We have moderate winters here maybe several times up to 8" snow. What size insulation would you suggest without putting any fur downs on bottom of rafters? Could go with 2x12 but expense begins to play into that.
Old 09-22-2009, 09:22 AM   #4
Registered User
Termite's Avatar
Southern Yellow Pine will certainly make the span as well.
You need to determine the minimum require R factor in your specific area/jurisdiction, which is often a local requirement. A call to the building codes office will let you know what they'll require. Then you'll know how far you need to fur down, which is easy and inexpensive to do.
Old 09-22-2009, 02:16 PM   #5
Registered User
Rewards Points: 5,216
Check the Pink Panther's web site for R-30c and R-38c, special denser glass specifically for cathedral ceilings that give you the ratings plus 1" air space. Also here are some comparisons after you find your local requirements: http://hes.lbl.gov/hes/makingithappe...omparison.html
And if you can afford it, an R-65: http://www.lowes.com/lowes/lkn?actio...065&lpage=none
Be safe, Gary
Condensation on cathedral ceiling barbaraizac Roofing/Siding 46 09-26-2009 11:48 PM
inulation above cathedral ceiling LanterDan Building & Construction 14 06-11-2008 03:57 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 02:18 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 11:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
