Cat 5 To Phone Wall Jack - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 05:36 PM   #1
Rewards Points: 276
cat 5 to phone wall jack
I ma posting here because this should be fairly simple and this category gets more views than the pc one.....I have cat 5 wire and need to wire to a regular phone wall plate, ie: orange, green, blue, brown solid/stripped, what goes to the red, green, black, yellow screws on plate???
ugabulldog is offline   Reply With Quote
Old 11-30-2010, 05:45 PM   #2
What ever colors you used at the other end
Old 11-30-2010, 05:48 PM   #3
Electrician
Notice that you only have to connect the green and red unless you are using a 2-line phone.
VersaBar is offline   Reply With Quote
Old 11-30-2010, 08:08 PM   #4
Rewards Points: 276
so don't connect the black or yellow for a single line and will it affect anything if I go ahead and connect both sets?? thanks for the pic
Old 11-30-2010, 08:15 PM   #5
Electrician
Originally Posted by ugabulldog View Post
so don't connect the black or yellow for a single line??
You could if you like, it won't hurt. But if you know that you'll never use it, you don't have to waste your time with it. Your best bet is to pay 100% attention to the green and red and make sure they are connected properly and securely.
The Following User Says Thank You to VersaBar For This Useful Post:
ugabulldog (12-01-2010)
Cable, Phone box & Roof Jack Steve Burke Electrical 3 11-17-2009 05:13 PM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 Electrical 18 10-03-2009 10:20 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-17-2007 11:46 PM
Installation of new phone jack alvanos Electrical 4 04-05-2006 06:12 PM
