The Case Of The Hanging Base Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2008, 08:03 PM   #1
The case of the hanging base plate
While doing an addition to my garage, I discovered that one of the garage walls was defectively framed. It's a slab on grade with a 6" wide curb on which the base plate is mounted. The problem is that for whatever reason the wall was framed with the base plate hanging out off the curb towards the exterior by more than an inch, so there's barely half the width of the base plate being supported by the foundation. (It's 2x4 construction.) The garage was built 20 years ago so I don't think that it's going anywhere, but I feel like I should do something to strengthen it now that I know about it. My thought was to lay another 2x4 base plate on the curb on the interior, redhead it into the curb, and then tie the new base plate to the old with some kind of Simpson connector. Any thoughts on whether this would do any good and the best way to tie the two plates together? Thanks for any ideas.
KaiserS is offline   Reply With Quote
Old 01-31-2008, 08:27 PM   #2
I don't understand your post. A 2x4 wall base plate is 3 5/8" wide. If its hanging off by 1", then its still got 2 5/8" sitting on the concrete. That's more than 2/3. I would just have a few more beers and forget about it, unless you are afraid you are going to run into the wall again with your car, and if that's the case then just install some 4" pipe bollards or put some heavy machinery or something like that in front of the wall.
nacko is offline   Reply With Quote
Old 01-31-2008, 08:59 PM   #3
Thanks for your reply. The base plate is actually hanging off by an inch and a quarter, and the plate is closer to 3 3/8" wide, not 3 5/8", so its got about 2 1/8" bearing on the curb. So it is more than half on the curb, but not by a lot. I should also have said that I'm in California so seismic activity is a factor. (Although when the Big One hits this plate will be the least of my worries.) Does that change your answer at all? Thanks.
Old 01-31-2008, 09:41 PM   #4
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
its been there for 20 years so I doubt its a big problem now, you could bolt or tapcon a 2x4 under the plate on the outside then nail down into it fairly easy I would think
Kingfisher is offline   Reply With Quote
Old 02-02-2008, 06:42 PM   #5
Rewards Points: 150
Don't worry about it. Garages don't have a lot of weight to them. Don't store a lot of stuff up in the ceiling.
kgphoto is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
Sill plate and pre-hung door sithappens Building & Construction 4 01-27-2008 06:18 AM
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 06:38 AM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
