Carrier Beam Directly On Concrete ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 05:53 AM   #1
Carrier beam directly on concrete ?
I'll be notching a pocket into my concrete frost wall to set the carrying beam into it, this is going to be 3 - 2x12 SP (w/ plywood between). Do they make some type of metal bracket so the wood is not directly against the concrete?
vtboy51 is offline   Reply With Quote
Old 03-16-2012, 07:09 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Simpson ST Brackets Here: http://www.strongtie.com/literature/...l?source=promo
Also, if the plans and/or engineering requirments don't dictate mechanical fastening (bracket-use with proper nails, lags or screws), you can wrap wood with Ice & Water membrane to separate it from concrete contact.
- Build Well -
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Floor "bells" over the center carrier beam... RyanUsesThis Flooring 8 05-11-2009 05:00 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
